It is currently Wed Jul 16, 2025 9:12 pm
Reply to topic  [ 11 posts ]
 set up first mm
Post set up first mm
Just bought a used copperhead 12 .. got it on a 1648 flat polarcrap .. I've never owned a mm .. my question is the motor runs and planes out good but pushes hard to the right .. I moved it alight each way trying to get it to not push ... Should it be centered .. is this just what they do ..?
1648 polar Crap ducks unlimited 14 hp. Copperhead
Tue Jul 10, 2012 11:36 am
Post Re: set up first mm
Sounds like you need to bend the end of the skeg to eliminate the tiller torque. It looks like it is set up to do this, it just hasn't been done yet. Probably wouldn't hurt to call Copperhead and let them advise you on it.
Tue Jul 10, 2012 11:54 am
X2^^^bend the skeg also just do a little bend at a time and test it it don't take much
Tue Jul 10, 2012 1:57 pm
If ur at the prop looking forward to front of boat the prop wants to go left .. tiller handle to right .. which way do I bend skeg
Tue Jul 10, 2012 3:15 pm
Bend the skeg in the direction you want the boat to go. For example, bending it to port side will make the boat track towards the port side.
Tue Jul 10, 2012 3:58 pm
Ok I thought so ... Is this normal ? Do other brand have an angled skeg ..
Tue Jul 10, 2012 4:56 pm
Yes, but the ones I know of are bent from the factory and you just "adjust" them based on you boat's handling
Tue Jul 10, 2012 5:10 pm
The skeg is angled on my Copperhead. I can tell you from experience though that if you are running with the prop too high out of the water, the steering torque can be so bad you cannot steer and it is not optimal for speed either. As soon as you drop it a little the problem goes away. There is a learning curve to knowing how to run it.
Wed Jul 11, 2012 12:52 am
X2 on the prop position. The prop needs to be trimed right or it will cause the engine to pull hard, in my case, to the right. Call Gil at Copperhead. He will be able to talk you thru it. What sort of speeds did you get?
Copperhead Manufacturing LLC
2023 Philip Dr
Suite B
Covington LA 70433
Phone – 985-893-2790
Later and congrats on your new engine.
Wed Jul 11, 2012 2:32 pm
Thanks guys ... Wow I emailed gil at copperhead and got a responds right away.. gained some great info and thanks to good ole America customer service ! Got it figured out ..
Wed Jul 11, 2012 6:02 pm
Great to hear. Gil has always been helpful and available when I needed him.
Rogue 16X38 w/ a 18hp Copperhead
Wed Jul 11, 2012 6:07 pm
Users browsing this forum: No registered users and 99 guests
