It is currently Wed Jul 16, 2025 9:00 pm
Reply to topic  [ 12 posts ]
 This problem has me puzzled
Post This problem has me puzzled
Ok 35 vanguard marine motor I can idle and run no more than 1400 rpm and any faster it will get on plane for about 30 seconds and then just die !! I put a new fuel pump took out the primer ball checked all fuel lines and cleaned carb!! I'm puzzled so any help would awesome!
Sat Jul 07, 2012 11:25 am
Post Re: This problem has me puzzled
Sounds like its getting air
Sat Jul 07, 2012 12:22 pm
air or need to clean the carb, float maybe sticking or trash in it
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Sat Jul 07, 2012 1:24 pm
Valves
I gave up mud motors
Sat Jul 07, 2012 2:13 pm
Maybe bad fuel, if you have fuel and air, it has to be ignition, check plugs, plug wires, something may be breaking down on the ignition side, make sure your gas tank isn't air locked...
Sat Jul 07, 2012 4:01 pm
well i took carb down again and adjusted my float cause it didnt look like it was dropping enough and that helped a little but still cant get wide open and unhooked fuel line from tank and the line held fuel1 So if the rain would ever stop im going to try a electric fuel pump!! and WOW no help from deadbird8,boatdr or 50hptiller!!!!! LOL
Tue Jul 10, 2012 11:01 am
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Tue Jul 10, 2012 11:34 am
You didn't happen to close the vent on the tank and forget to open back up? I did that once after cleaning the boat out with a pressure washer and acted very similar until I saw the tank sucked in. LOL
Thu Jul 12, 2012 4:38 am
Gas Tank Vent should run wide open for a little while...I highly doubt that is the problem. I mean it could be but jeez that would be the first thing a guy would check right?
Sounds electrical. Do you have a rev limiter on it?
whats your plugs look like? Gapped properly? That still shouldn't cause it to shut down completely..
Thu Jul 12, 2012 5:51 am
Man I wish it was that easy I went as far as putting my gas hose straight in the fill hole without that cap on!! And when I shuts down the fuel filter is still full with gas and after it dies u have to crank it a few times and pull the choke for it to crank back up !!
Thu Jul 12, 2012 8:46 am
Yes new pulse pump and my motor came without the anti backfire solinoed and without oil pressure switch butt I do have a oil pressure gage and it reads about 40 lbs and oil level is good. and when i had the primer ball on the fuel line it sucked flat on time so thats when i cleaned out my tank and check the little filter on the tank line and removed it and i also got rid of my quick connect on my tank also. and the other day i pulled the fuel line off of the tank(opened hose no fitting) and my glass fuel filter stayed full so that should mean that the line doesnt have any leaks!! And i have a in-line electric fuel pump im going to try next time on the water!!! but i did run it in the drive way and with no load i can sit in the cdi rev limter!!
Thu Jul 12, 2012 11:43 am
Well low and behold it was a bad fuel line the in plastic liner ate up and was causeing a clog!!!!!!!!
Sun Jul 15, 2012 8:49 pm
Users browsing this forum: No registered users and 89 guests
