mudder
Joined: Sun Jan 25, 2009 11:25 am Posts: 401 Location: Wisconsin
 Oil Leak at the filter, PD36
I just changed the oil in my prodrive yesterday and noticed there still is a very small amount of oil if I rub my finger at the seal of the filter. I mean very little, about an eye droplet. No visual drips or anything. I hand tightened the filter like you are supposed to, but I did crank it a little by hand.
I just ran the boat today and had the same eye droplet of oil when running a finger around the bottom of the filter seal. Anything to be concerned about?
Thanks
_________________ Phowler Extreme 1848 with 36PDFPR
Sun Aug 12, 2012 5:26 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: Oil Leak at the filter, PD36
Probably the o-ring behind the stainless filter mount (for lack of a better term) where the lines take oil through the filter and back to the motor. Take the filter off and there is a nut that holds it on behind the filter. Those rings will stretch and start to leak a little. You can clean it real good and put some rat gasket sealer in there, let it set up, and put the filter and oil back on.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Sun Aug 12, 2012 5:34 pm |
mudder
Thanks Mizz.
If I remove the filter should I replace with a new one? I assume I wont loose alot of oil, just what the filter is holding??????
Sun Aug 12, 2012 6:50 pm |
mizzippi jb
No, just add back what came out with the filter.
Sun Aug 12, 2012 7:01 pm |
POKER1
Did it leak before the filter change or just with the new one?
Sun Aug 12, 2012 7:32 pm |
mudder
Sun Aug 12, 2012 8:30 pm |
WestEndAngler
MMT Moderator
I've had a filter do that. I replaced it with a new one and it didn't leak... I took it back to the auto parts store and they took the exchange.
Sun Aug 12, 2012 8:35 pm |
mudder
Sun Aug 12, 2012 8:48 pm |
POKER1
Sun Aug 12, 2012 9:45 pm |
BoatDR
I'd degrease it as well as possible and just make sure that the oil isnt coming from the 90 degree that the oil cooler hoses attach to. I have had a bunch of them come in recently leaking at the threads.
Mon Aug 13, 2012 7:54 am |
mudder
Mon Aug 13, 2012 10:29 am |
mudder
Mon Aug 13, 2012 10:32 am |
Will
If that little drip bothered you wait until that case gasket starts leaking. LOL. The way I figure it, if it's not leaking enough to need to had oil between oil changes, it's not enough to worry about plus it keeps the rust and salt water termites away.
Mon Aug 13, 2012 10:48 am |
POKER1
A drop of oil can spread and look like a whole lot. You will learn to live with it if stick with a MM.
Mon Aug 13, 2012 11:02 am |
mudder
I agree with you both. I think I may just leave it and not be so anal about it unless it gets bigger. I have been keeping an eye on my case gasket especially since I am just over 200 hrs. This will a good time to put in a performance cam as well. Thanks again for the good advise.
Mon Aug 13, 2012 12:28 pm |
mizzippi jb
go around the case and tighten em up ever so often. Mine was leaking a little when I bought it but the bolts were loose. I tightened em up and it hasn't leaked since.
Mon Aug 13, 2012 6:26 pm |
