It is currently Fri Jul 18, 2025 1:50 pm
Reply to topic  [ 6 posts ]
 Wont turn over...
Post Wont turn over...
Mud Buddy HD Sport
29 Kawasaki w/ Electronic Fuel Injection and Liquid Cooled
Out on Saturday. Running just fine for an hour. Motor killed. Fuel pump would not prime and engine would not turn over. Now fuel pump primes, but no turnover.
Ideas?
Thanks!
Tue Sep 04, 2012 7:17 pm
Post Re: Wont turn over...
If it won't turn over at all check your battery connections. Or do you mean it won't start when you crank it? You mentioned a fuel issue...but that wouldn't have anything to do with a motor not turning over.
Tue Sep 04, 2012 7:20 pm
Battery is full charge and connections are clean. It will not turn over at all. Turn the key and nothing...
Tue Sep 04, 2012 8:58 pm
Sounds like a bad ignition switch or short between switch & starter
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Sep 04, 2012 9:54 pm
You got it, Team Camo.
Thanks for your help.
Turns out the starter solendoid was not getting the voltage needed, so we traced it back to the key switch, which had extreme corrossion. Cleaned that up real well, applied silicone terminal grease to terminals, and we are golden.
Paul
Thu Sep 06, 2012 12:12 pm
Good deal, glad I could help
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Sep 06, 2012 4:28 pm
Users browsing this forum: No registered users and 143 guests
