It is currently Thu Jul 17, 2025 5:20 pm
[ 7 posts ] |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Engine temp?
Just bought an Airboat with a big block 454. I'm curious about what temp the engine should run. The boat has an oil cooler mounted at the top of the cage. The temp when running it hard stays about 120-130deg. When idleing it'll go to 140deg. I know too much heat is bad, and also not enough is bad. Is this about right or should it be running a little warmer.
BTW i posted on ABT also. I just want an answer this year.
Mon Sep 17, 2012 9:08 am |
MaXXis85
 Re: Engine temp?
Oil or coolant temp? Coolant temp should be 160-190 ish depending on your thermostat. Oil temp should be close to the coolant temp IIRC.
Mon Sep 17, 2012 9:16 am |
msm8281
 Re: Engine temp?
Not really sure but I think it the coolant temp. I don't have the boat with me now.
Mon Sep 17, 2012 9:19 am |
MaXXis85
 Re: Engine temp?
That temp seemd low. Do you even have a themostat in the engine?
Mon Sep 17, 2012 9:22 am |
msm8281
 Re: Engine temp?
I don't think so. i bought the boat used. From what i hear not many people run thermostats on airboats because most of them run on the warmer side when you run at an average of 3800 to 5000 rps all the time.
Mon Sep 17, 2012 9:25 am |
Fowlmood
Joined: Mon Jul 18, 2011 11:24 am Posts: 230 Location: centerville,la
 Re: Engine temp?
the cooler it runs the better in the heat of the summer it shouldnt be more than 190-200
_________________ 17x 54 with a 35GTR with Calens stage 1
Mon Sep 17, 2012 12:50 pm |
msm8281
 Re: Engine temp?
Mon Sep 17, 2012 2:01 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 111 guests |
