bradmiller_rn
 Trouble with Trim
Hello all, I am new to this forum and am having trouble with the trim on a GT. The trim has always worked well with no problems, but my father let the boat sit up over the summer and now the trim doesnt work at all. Neither up or down works. I tried cranking motor, but that didnt work either. I definitely am no marine mechanic, so any help would be appreciated. Thank you in advance.
Mon Sep 17, 2012 1:34 am |
marsh mule
Joined: Wed Oct 27, 2010 6:08 pm Posts: 663 Location: setx
 Re: Trouble with Trim
U have the tiller control box or the 65 foot of wires in your battery box?
_________________ 23gtr crossover Mikuni
Mon Sep 17, 2012 1:54 am |
bradmiller_rn
I have the tiller box.
Mon Sep 17, 2012 5:30 am |
Team Camo
Charge the battery or hook it back up
Mon Sep 17, 2012 6:13 am |
deltaduckmaster
Mon Sep 17, 2012 6:29 am |
deltaduckmaster
O
Mon Sep 17, 2012 6:30 am |
deltaduckmaster
Did you look at fuse!!
Mon Sep 17, 2012 6:36 am |
Team Camo
Mon Sep 17, 2012 7:02 am |
Moultrie
Is there any noise coming from the motor on the unit. May be fluid.
Mon Sep 17, 2012 7:17 am |
craig
Charge your battery.
Mon Sep 17, 2012 7:54 am |
bradmiller_rn
Thank yall for all the info. I had already tried to charge the battery. No, there isnt any noise at all when I try the trim. There is no bad wiring that I can find. I am guessing that it is a bad fuse or relay.
Tue Sep 18, 2012 5:05 am |
Moultrie
To my understanding the switches in the tiller control box can handle to full amp load, doing away with relays.
Tue Sep 18, 2012 5:29 am |
MaXXis85
Is your battery charged? Just because you "tried" to charge it dosen't mean it is charged. Get a MultiMeter and test it.
Tue Sep 18, 2012 5:32 am |
CootSlayerRMFT
Joined: Thu Feb 02, 2012 12:53 am Posts: 7565 Location: Prairieville, LA
Bump for Giga and Robn...
Tue Sep 18, 2012 7:43 am |
Gigafowl
Ok - try cranking the engine with the charger connected and set to the high amp setting like 20 or 50 amp....
It should click - grind - or something then....
Sittin up a boat battery on an aluminum boat will drain down to nada....
Tue Sep 18, 2012 4:06 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Tue Sep 18, 2012 7:25 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
And once it sits there discharged for any length of time, just go ahead and buy a new one because that one is ruined and will never hold a charge correctly again.
Tue Sep 18, 2012 8:01 pm |
MaXXis85
Wed Sep 19, 2012 6:32 am |
