It is currently Fri Jul 18, 2025 10:52 am
Reply to topic  [ 18 posts ]
 Trouble with Trim
Post Trouble with Trim
Hello all, I am new to this forum and am having trouble with the trim on a GT. The trim has always worked well with no problems, but my father let the boat sit up over the summer and now the trim doesnt work at all. Neither up or down works. I tried cranking motor, but that didnt work either. I definitely am no marine mechanic, so any help would be appreciated. Thank you in advance.
Mon Sep 17, 2012 1:34 am
Post Re: Trouble with Trim
U have the tiller control box or the 65 foot of wires in your battery box?
23gtr crossover Mikuni
Mon Sep 17, 2012 1:54 am
I have the tiller box.
Mon Sep 17, 2012 5:30 am
Charge the battery or hook it back up
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Sep 17, 2012 6:13 am
17x48 extreme stage 2 GTR
Mon Sep 17, 2012 6:29 am
O
Mon Sep 17, 2012 6:30 am
Did you look at fuse!!
Mon Sep 17, 2012 6:36 am
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Mon Sep 17, 2012 7:02 am
Is there any noise coming from the motor on the unit. May be fluid.
Mon Sep 17, 2012 7:17 am
Charge your battery.
Mon Sep 17, 2012 7:54 am
Thank yall for all the info. I had already tried to charge the battery. No, there isnt any noise at all when I try the trim. There is no bad wiring that I can find. I am guessing that it is a bad fuse or relay.
Tue Sep 18, 2012 5:05 am
To my understanding the switches in the tiller control box can handle to full amp load, doing away with relays.
Tue Sep 18, 2012 5:29 am
Is your battery charged? Just because you "tried" to charge it dosen't mean it is charged. Get a MultiMeter and test it.
Tue Sep 18, 2012 5:32 am
Bump for Giga and Robn... :lol: :lol:
Tue Sep 18, 2012 7:43 am
Ok - try cranking the engine with the charger connected and set to
the high amp setting like 20 or 50 amp....
It should click - grind - or something then....
Sittin up a boat battery on an aluminum boat will drain down to nada....
Eat - Sleep - Hunt ! ! !
Tue Sep 18, 2012 4:06 pm
Tue Sep 18, 2012 7:25 pm
And once it sits there discharged for any length of time, just go ahead and buy a new one because that one is ruined and will never hold a charge correctly again.
Tue Sep 18, 2012 8:01 pm
Wed Sep 19, 2012 6:32 am
Users browsing this forum: No registered users and 123 guests
