It is currently Thu Jul 17, 2025 11:50 am
Reply to topic  [ 7 posts ]
 Engine temp?
Post Engine temp?
Just bought an Airboat with a big block 454. I'm curious about what temp the engine should run. The boat has an oil cooler mounted at the top of the cage. The temp when running it hard stays about 120-130deg. When idleing it'll go to 140deg. I know too much heat is bad, and also not enough is bad. Is this about right or should it be running a little warmer.
BTW i posted on ABT also. I just want an answer this year.
Mon Sep 17, 2012 9:08 am
Post Re: Engine temp?
Oil or coolant temp? Coolant temp should be 160-190 ish depending on your thermostat. Oil temp should be close to the coolant temp IIRC.
Mon Sep 17, 2012 9:16 am
Not really sure but I think it the coolant temp. I don't have the boat with me now.
Mon Sep 17, 2012 9:19 am
That temp seemd low. Do you even have a themostat in the engine?
Mon Sep 17, 2012 9:22 am
I don't think so. i bought the boat used. From what i hear not many people run thermostats on airboats because most of them run on the warmer side when you run at an average of 3800 to 5000 rps all the time.
Mon Sep 17, 2012 9:25 am
the cooler it runs the better in the heat of the summer it shouldnt be more than 190-200
17x 54 with a 35GTR with Calens stage 1
Mon Sep 17, 2012 12:50 pm
Mon Sep 17, 2012 2:01 pm
Users browsing this forum: No registered users and 108 guests
