It is currently Fri Jun 27, 2025 1:10 am
Reply to topic  [ 11 posts ]
 gtr 35 backfiring under load
Post gtr 35 backfiring under load
Last night took the boat out and the port engine would back fire , have no power and die when the clutch was engaged. It did this twice over about 4 hours and it only did it for a few minutes. Start it back up after messing with it and it would run fine anyone have any ides
Thu Oct 15, 2009 2:15 pm
Post Re: gtr 35 backfiring under load
Dude you're still under warranty. Give da fine folks at GT a call and they will fix you up.
Thu Oct 15, 2009 7:02 pm
My GT is brand new and is doing the same thing. Idling rough and kills when engaged. I'm sure it's the carb and i'm bringing it in tomorrow.
Did you determine what the problem is with yours?
Mon Oct 19, 2009 8:31 pm
MMT Moderator
Mine was doing this I found out that the wires behind the tilt up / down switch and forward / start button were not tucked all the way up in there and somehow had got pinched in the trim motor... I guarantee you that's your issue... Go pull that cover off and inspect the wires tape up any that may have had the covers exposed to bare metal cause its shorting out.
GTB 1860 w/ 2019 GTR40XD-HO
Mon Oct 19, 2009 9:05 pm
Tue Oct 20, 2009 8:19 pm
I sent Westend's post (wires) to Hoyt and he replied that my issues were probably different, carb i suppose.
They should be done by friday so i'll post the results.
Tue Oct 20, 2009 8:29 pm
MMT Moderator
My issue arose after my trim up wire came lose after I was doing some maintenance.
When I replaced the cover the wires were hanging down and one got pinched so 1/2 way into a shallow lake I start back firing... I knew that was the problem when I saw wire exposed. Popped the cover back off put some electrical tape around wire and tucked everything back up in there...
Hope you get your problem worked out. Hoyt knows best :lol:
Tue Oct 20, 2009 8:39 pm
Wed Oct 21, 2009 10:39 am
Got the boat back from GT. Cause of the problem was a piece of debris in sparkplug boot tween tip and connector. I didn't have my 5/8's with me at the landing so i never did/could check the plugs. I have one now.
Hoyt said this is the third motor to have this issue.
Runs good now...two people, full tank...28.2 mph. Boat's a 17/54 btw.
Sun Oct 25, 2009 7:56 pm
Thanks for the infor cypress and congrats on the speeed
Thu Oct 29, 2009 4:32 am
Well, i went out yesterday and took a fresh tank of gas with no ethanol and tried to crank up the motor...would not start...probably still bad gas in the line...checked the plugs and they looked great...sprayed a little "engine start" in the carb and she cranked right up...let the motor run for about 5-10 minutes and it would seem to idle good...but if i ran the rpms up to about 3,000 or so, i still get a surging sound, like it is bumping the governer. And then If I run up the rpms and then let off the throttle, i get a pretty good back-fire. Do ya'll think this is the same electrical thing that Westend was having, or something else? Thanks,
Woody
17x54 Gator-Tail w/ 35HP GTR
Gator-tail/MM exhaust
Center Console...it fixes tiller torque
viewtopic.php?f=4&t=9330
Mon Nov 02, 2009 10:00 am
Users browsing this forum: No registered users and 84 guests
