It is currently Thu Jun 26, 2025 10:49 am
[ 8 posts ] |
MIKUNI PROBLEMS WITH COLD WEATHER
Jamie B.
When im getting on the throttle from a idle at about 3800 RPMs my motor seems to sputter then if i come of the throttle a lil bit it will catch back up to be able to use full throttle. Im running a 165 main jet with evt intake, heads, cam, timing advance, and exhaust do i need to put a e fuel pump? The motor does not miss a step when its not below 50 degrees.
Fri Dec 04, 2009 9:12 am |
MaXXis85
 Re: MIKUNI PROBLEMS WITH COLD WEATHER
You may ne experiencing Carb icing. If it is humid in your area it will add to the effect of the carb icing.
Fri Dec 04, 2009 9:31 am |
Jamie B.
What can i do to fix this problem it seems like when its about 40 degrees i can only get about 4100 RPm when i usally run above 4500
Fri Dec 04, 2009 9:40 am |
indybill
Joined: Wed Jan 14, 2009 7:38 pm Posts: 581 Location: HOUSTON
What Grade of Gasoline are you burning???
_________________ My Chessie is the Queen of the Marsh!!!!
"The democracy will cease to exist when you take away from those who were willing to work and give to those who would not." Thomas Jefferson-1802
"When the Government fears the people that is liberty When the people fear the government that is tyranny"- Thomas Jefferson
Fri Dec 04, 2009 9:47 am |
Jamie B.
93 octane
Fri Dec 04, 2009 10:01 am |
DMC
Joined: Sun Jan 25, 2009 7:23 pm Posts: 204 Location: Bayou House!
It might be a little on the lean side in the cold weather. Try a little bigger jet or a little more pump shot. Let us know what you find. Good luck
Fri Dec 04, 2009 10:11 am |
Jamie B.
already tried a 167.5 jet and it got flat on top end and my accel. pump is set where you can just slide a peice of paper between the white plastic and the pump rod and per silk at evt
Fri Dec 04, 2009 1:39 pm |
OwenDickeson
i know you cant do this with the mikuni setup but when it gets real cold here my motor will do the same...but i just turn the air filter box to where the air intake is facing down by the muffler and it gets hot air and no more problems...not sure what you could do with the mikuni setups i posted a question a while back seeing if guys were experiencing carb icing with the mikunis setups cuz i was considering ordering one. didnt really get any responses but here is the link
Fri Dec 04, 2009 1:59 pm |
[ 8 posts ] |
Users browsing this forum: Google [Bot], treyterr567 and 161 guests |
