It is currently Thu Jun 26, 2025 3:15 pm
Reply to topic  [ 14 posts ]
 Help
Post Help
I just returned home after a 3 hr drive with my brand new 36 hp FPR Prodrive. The motor will not even turn over. When I turn the key it goes clunk like the engine is locked up. Battery appears to have 12.5 volts. Do you guys have any suggestions? I can not get the dealer to answer the phone at this hour, I suppose I will have to wait until tomorrow.
2010 1854 Prodrive CC - 2010 36 Prodrive FPR Hyd T&T
Thu Dec 10, 2009 6:43 pm
Post Re: Help
throw some jumper cables on the battery and your truck and see what it does (I know you said you tested the battery, but that crap can be weird). Just start trouble-shooting from the battery to the starter checking for loose connections.
Sorry I cant be ore help.
WC 1848 Bateau w/ 36 PD FPR
Thu Dec 10, 2009 6:53 pm
Post Re: Help
Make sure da clutch is not ingauged.
Thu Dec 10, 2009 7:07 pm
Post Re: Help
Thu Dec 10, 2009 8:01 pm
Post Re: Help
Turn it on..
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Thu Dec 10, 2009 8:02 pm
Post Re: Help
check to make sure the connections to the starter are tight and the ground connections are tight.
Also the battery may appear good, but it could have a bad cell.
try another battery out of your truck or use jumper cables.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Thu Dec 10, 2009 8:28 pm
Post Re: Help
It will roll over with no kill switch. Make sure the clutch knob is pushed in as stated. That single "clunk" is the noise it makes if engaged.
18x48 Charles Leonard / 36PD
Thu Dec 10, 2009 9:20 pm
Post Re: Help
hell that's a brand new unit ,they should of ran it before they let you have it.you may have to paddle that bastard around to get to your favorite hunting hole.i grant you that it just a low battery.
Thu Dec 10, 2009 10:20 pm
Post Re: Help
Your probably just a little to dam excited about your new motor and hook the cables up wrong.
Thu Dec 10, 2009 10:26 pm
Post Re: Help
hell when i got my new gdsd last week,i was working on it till 10 30 pm then i took it out on the lake.And everything was working against me. by god it was going to the lake whether it hear lip the pope!
Thu Dec 10, 2009 10:35 pm
Post Re: Help
OK Guys,
Thanks for the helpful replys, I ignored the useless ones, but I put the battery on charge all night long and tried it again this morning. At first a single clunk but I stayed on the key and it finally began a real slow grind and finally a good spin. Now it spins freely and starts very easily.
Thanks again for the guys that tried to help.
Fri Dec 11, 2009 8:19 am
Post Re: Help
that pd going to be bad ass.your going to need two batteries in parallel just to start it. sound like you you v got a lot of compression on it.
Fri Dec 11, 2009 8:42 am
Post Re: Help
12.5 volts is not fully charged. have the battery tested with a conductance tester.
Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Fri Dec 11, 2009 8:45 am
Post Re: Help
Uncle J 1848 w/?
Fri Dec 11, 2009 6:56 pm
Users browsing this forum: No registered users and 109 guests
