It is currently Mon Feb 02, 2026 11:55 am
Reply to topic  [ 3 posts ]
 How can I tell if I need a new clutch?
Post How can I tell if I need a new clutch?
Changed that case gasket today and during disassembly noticed quite a bit of metal shavings in the outdrive. The clutch felt like it slipped a couple times the last couple of runs I made on the boat before changing the gasket. I checked belt tension first and it was only 9 lbs, so that may have been the problem. There is visible wear on both sides of the clutch surfaces. Should I take her for a test drive or go ahead and call the Boat Dr?
Sun Feb 21, 2016 12:35 am
Post Re: How can I tell if I need a new clutch?
Refurbishing a Prodrive
Sun Feb 21, 2016 12:51 am
Ran great in the test run today but I ma gonna call Boat Dr and check on the parts. I am like u, I feel like I should go ahead and change it.
Mon Feb 22, 2016 2:44 am
