It is currently Mon Feb 02, 2026 4:47 pm
[ 3 posts ] |
How can I tell if I need a new clutch?
tlsmith22
Joined: Sat Jan 08, 2011 8:01 pm Posts: 175 Location: North Alabama
Changed that case gasket today and during disassembly noticed quite a bit of metal shavings in the outdrive. The clutch felt like it slipped a couple times the last couple of runs I made on the boat before changing the gasket. I checked belt tension first and it was only 9 lbs, so that may have been the problem. There is visible wear on both sides of the clutch surfaces. Should I take her for a test drive or go ahead and call the Boat Dr?
| Sun Feb 21, 2016 12:35 am |
brycecheramie
 Re: How can I tell if I need a new clutch?
| Sun Feb 21, 2016 12:51 am |
tlsmith22
Ran great in the test run today but I ma gonna call Boat Dr and check on the parts. I am like u, I feel like I should go ahead and change it.
| Mon Feb 22, 2016 2:44 am |
[ 3 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 2 guests |
