It is currently Thu Apr 09, 2026 5:03 pm
[ 6 posts ] |
tystorm
 briggs 31hp
whats the story on the briggs 31? i have a 24 longtail and have been looing for a 35 sd but found a 31 hyperdrive and just havent heard much about these motors. are they the same block as the 35? do parts interchange? any help is appreciated. thanks
| Wed May 11, 2016 6:49 am |
MaXXis85
 Re: briggs 31hp
| Wed May 11, 2016 6:50 am |
BlackTJ35
 Re: briggs 31hp
Same block different oil passages to the main bearings. 31 main bearings are oiled through the crank, 35 is oiled through the block. If you put a 35 crank in a 31 block it will seize up due to the front main bearing not getting oil. Everything else is the same except rods and crank, 31 has a shorter stroke. Also wouldn't recommend mixing 31&35 crank and flywheel, you will have vibrations
| Sun Jun 19, 2016 9:35 pm |
MaXXis85
 Re: briggs 31hp
| Mon Jun 20, 2016 5:37 am |
cb5331
 Re: briggs 31hp
Different carb too
| Mon Jun 20, 2016 5:43 am |
MaXXis85
 Re: briggs 31hp
| Mon Jun 20, 2016 5:47 am |
[ 6 posts ] |
