It is currently Sun Apr 05, 2026 11:27 pm
[ 7 posts ] |
Saw something today on my PD
11Bravo
Mine is a 2007 36 PD and I ordered some new plug ends. I have read here about spark shorts to the shrouding from the boots. But looking things over I'm not happy to see the plug wires leaving the sheet metal without a grommet. I have worked on and owned a number of Military air cooled flat 4 cylinders for gen-sets, they all had grommets where the wires left the shrouding. What say's the folks that put lots of hours on theirs?
| Fri Jul 15, 2016 9:23 am |
Russ
 Re: Saw something today on my PD
I wrapped electrical tape on any wire where they passed through metal with edges. I check it fairly regularly. Never had any issues that adding a new wrap of tape doesn't fix.
| Fri Jul 15, 2016 9:54 am |
Will C
I like to put black silicone around wires after assy. Keeps them from vibrating and cutting
| Fri Jul 15, 2016 10:24 am |
ibfishinb
I put small split loom on my plug wires along with a grommet (redundant I know).
| Fri Jul 15, 2016 6:59 pm |
Quackhead62
Joined: Fri Nov 30, 2012 7:47 pm Posts: 931 Location: Maurice,La
_________________ Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust Pushing a 17X54 Pro-Drive X-Series boat
| Fri Jul 15, 2016 7:05 pm |
dead animal
I take a drillbit and drill out the hole in the top cover big enough to where the wires pass freely, then I put some tape on the plug wire. otherwise a tight fitting cover will ruin your plug wires.
| Fri Jul 15, 2016 7:59 pm |
banded-mallard
I must say, that on my Kawi, they thought of that. The Kawasaki has a rubber/plastic liner that's around the plug wire the entire way from coil to end. Found it by accident when I tried to install my Tach wire. I had to strip back about 1" near the plug so that the wire would get a good reading. Before, the tach was erratic. Best bet is to take some 1/4" fuel line, slice it open and put it around the plug wire similar to wire loom, should work and protect well.
| Mon Jul 18, 2016 4:46 am |
[ 7 posts ] |
