It is currently Wed Apr 08, 2026 8:06 pm
Reply to topic  [ 6 posts ]
 Oil breather line question
Post Oil breather line question
I just installed the 42mm carb kit and I noticed after running the motor I had oil blow by into the filter. The motor has pretty low hours on it so i can't imagine it's the rings already on my 35hp MB. Has anybody else seen this with there motor?
Sat Aug 13, 2016 6:41 pm
Post Re: Oil breather line question
Head gaskets pretty common failure
Sat Aug 13, 2016 8:55 pm
Are you filling past the full mark, up to the bend that some people recommend? If mine isn't 2.0qts exact, or less, it burps out the crankcase breather and is not a head gasket failure. Does it much more at 5,000 rpms.
GTR, Waitin' on a DFOU hull
Sat Aug 13, 2016 10:30 pm
^ overfill should have been first response. I jumped the gun on that one
Sun Aug 14, 2016 12:02 am
Mine does that when I'm carving a hard right hand turn for too long.;)
1754 prodigy- stage 2 GTR
Wed Aug 17, 2016 7:57 pm
But Briggs rings aren't known for the best seal either..
Thu Aug 18, 2016 9:49 am
