It is currently Sun Apr 12, 2026 3:58 am
[ 6 posts ] |
Oil breather line question
tmschuster
I just installed the 42mm carb kit and I noticed after running the motor I had oil blow by into the filter. The motor has pretty low hours on it so i can't imagine it's the rings already on my 35hp MB. Has anybody else seen this with there motor?
| Sat Aug 13, 2016 6:41 pm |
Will C
 Re: Oil breather line question
Head gaskets pretty common failure
| Sat Aug 13, 2016 8:55 pm |
Richard in LA
Joined: Tue Sep 08, 2009 1:58 am Posts: 282 Location: Prairieville, LA
Are you filling past the full mark, up to the bend that some people recommend? If mine isn't 2.0qts exact, or less, it burps out the crankcase breather and is not a head gasket failure. Does it much more at 5,000 rpms.
_________________ GTR, Waitin' on a DFOU hull
| Sat Aug 13, 2016 10:30 pm |
Will C
^ overfill should have been first response. I jumped the gun on that one
| Sun Aug 14, 2016 12:02 am |
krazo
Joined: Thu Sep 06, 2012 8:44 pm Posts: 667 Location: SE Bama
Mine does that when I'm carving a hard right hand turn for too long.  Sent from my iPad using Tapatalk
_________________ 1754 prodigy- stage 2 GTR
| Wed Aug 17, 2016 7:57 pm |
MaXXis85
But Briggs rings aren't known for the best seal either..
| Thu Aug 18, 2016 9:49 am |
[ 6 posts ] |
