It is currently Sun Apr 05, 2026 9:17 pm
Reply to topic  [ 12 posts ]
 Pro drive weird one
Post Pro drive weird one
You Prodrive gents ever seen the clutch locating bolts,"the long 5/16 bolts that just drop in" ride up and dig into engine sump? They dug in pretty hard and likely cracked sump housing.
Fri Sep 09, 2016 8:13 am
Post Re: Pro drive weird one
nope
Fri Sep 09, 2016 8:31 am
Did they not get seated properly when the powerhead was dropped in place? Only way I could see that happening.
Fri Sep 09, 2016 8:47 am
those are just in the bores being an anti rotation bolt.. Never have I seen them eat the sump cover.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Fri Sep 09, 2016 9:23 am
Fri Sep 09, 2016 10:31 am
Nope
Bayou Surface Drive
337-351-0362
Fri Sep 09, 2016 10:52 am
bolts that came out when he pulled power head were bent. He put new bolts and I made sure they were sitting down. He will prob stop by next week and I will get a better look. This is an old bolt, def has takin a beating, thanks for yalls input
Fri Sep 09, 2016 12:36 pm
The bolts shouldn't take a beating under normal circumstances, and I can't figure out how setting the power head down the them out of line would bend them. The only thing I can think of is they set the power head down and started tightening the 4 main bolts with those clutch aligning bolts in the wrong spot.
Fri Sep 09, 2016 1:02 pm
never seen them "ride" up.
If they are seated, they stay seated-gravity makes sure of it.
They should be free-not in a bind. That is the only way I can see it doing that-if they were in a bind and got stuck up somehow.
I do seem to recall years ago making some sort of mistake when reinstalling and getting them in a bind, but just can't remember what it was or what I did. Had to pull everything back apart and reset...
Good luck sorting it out.
Fri Sep 09, 2016 1:06 pm
Yea no way them bolts were seated in the bottom plate correctly.
Fri Sep 09, 2016 1:10 pm
The only way they got bent was when the power head/top plate was put back on, the bolts didn't get seated through the bottom plate. The big mounting bolts were tightened up bending the bolts. That's probably what cracked the tub. Vibration simply washed out the area that cracked.
Fri Sep 09, 2016 3:31 pm
