It is currently Sun Apr 05, 2026 8:19 pm
[ 6 posts ] |
Found something under valve cover
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Can anyone tell me what this is? I found it near the rockers when I was checking my valve lash (1st time since getting Iron Mountain heads 3 or 4 years ago). I'm 95% sure that it didn't fall in after the fact, but it's not out of the realm of possibility. I did have to stop and cover up my engine to go run errands a few times before I eventually saw it. It's small, round, reddish, plastic like and seems to be threaded on the inside. Any ideas where it came from? Thanks
| Sat Nov 05, 2016 12:59 am |
cb5331
 Re: Found something under valve cover
Part of a valve seal maybe?
| Sat Nov 05, 2016 5:28 am |
Will C
Is it rubber?
| Sat Nov 05, 2016 8:37 am |
Wilson
It's more like a hard plastic. What throws me off is the threads on the inside.
| Sat Nov 05, 2016 9:01 am |
Will C
If it's valve stem seal and prob is, checheck bottom of your rockers for marks where pushrods jumped out of place.this will smash the seals. I've seen this a few times. If it has I would recommend installing new pink springs with shims
| Sat Nov 05, 2016 10:23 am |
SCmudder7071
_________________ 1754 Extreme/LAProp Stage 2 GTR
| Sat Nov 05, 2016 10:43 pm |
[ 6 posts ] |
