It is currently Mon Apr 06, 2026 1:19 am
Reply to topic  [ 6 posts ]
 Found something under valve cover
Post Found something under valve cover
Can anyone tell me what this is? I found it near the rockers when I was checking my valve lash (1st time since getting Iron Mountain heads 3 or 4 years ago). I'm 95% sure that it didn't fall in after the fact, but it's not out of the realm of possibility. I did have to stop and cover up my engine to go run errands a few times before I eventually saw it. It's small, round, reddish, plastic like and seems to be threaded on the inside. Any ideas where it came from? Thanks
Sat Nov 05, 2016 12:59 am
Post Re: Found something under valve cover
Part of a valve seal maybe?
Sat Nov 05, 2016 5:28 am
Is it rubber?
Sat Nov 05, 2016 8:37 am
It's more like a hard plastic. What throws me off is the threads on the inside.
Sat Nov 05, 2016 9:01 am
If it's valve stem seal and prob is, checheck bottom of your rockers for marks where pushrods jumped out of place.this will smash the seals. I've seen this a few times. If it has I would recommend installing new pink springs with shims
Sat Nov 05, 2016 10:23 am
Sat Nov 05, 2016 10:43 pm
