It is currently Sun Apr 05, 2026 3:50 pm
Reply to topic  [ 10 posts ]
 Max RPMs without a Rev Limiter
Post Max RPMs without a Rev Limiter
Been wondering this lately, but what are the max RPM's without a Rev Limiter. Decked heads, exhaust I normally am between 4100 and 4200, but it jumped to over 4200 with a new prop. From what I have read here, seems like the limiter is needed for over 4350. Does that sound correct?
Thanks
Phowler Extreme 1848 with 36PDFPR
Mon Nov 07, 2016 2:36 pm
Post Re: Max RPMs without a Rev Limiter
Are u cdi ? Shimmed springs?
Mon Nov 07, 2016 2:48 pm
non cdi, 2008,. since I dont understand the second part I would say no. LOL
Mon Nov 07, 2016 3:55 pm
I also have a habit to not run at WOT when running and if I do, I dont do it for very long, but I normally run between 4100 and 4200 previously if I was WOT
Mon Nov 07, 2016 3:57 pm
Factory valves and springs will usually float just above 4200. aside from the fear of dropping a pushrod etc you are likely not going to spin it high enough to sling a rod. .... but sometimes shit happens :D
Mon Nov 07, 2016 5:16 pm
nobody cuts grass at half throttle. run that biatch wfo. mine is old and I like to keep it under 4300 and run it like that all day. I put the high rev coils in last year or so and put the high rev valve springs. I spin it 4500+ in the mud when busting trail and don't think twice about it.
when u hear the valves making noise, just back off a tad. lol
Mon Nov 07, 2016 7:58 pm
Thanks guys, just a general question I have been wondering about. I just finally ordered the K & N filter instead of the Briggs. Will plan on the easy mod to the carb shield I have also read about here. Easy project for Spring since our season is almost over. Without some northern winds, though, this season will continue to suck. :cry:
Tue Nov 08, 2016 9:14 am
So I figured out why my RPM's jumped by almost 100 RPMs. I forgot I just added the K & N air filter. :D
Tue Nov 29, 2016 12:08 pm
My first truck was a 4cylinder, 5 speed with no tach on the dash, I'd let it pull until I heard the valves float and then shift gears, finally got use to the sound and would shift right before they floated, put almost 200K miles on it. haha
Tue Nov 29, 2016 12:55 pm
Tue Nov 29, 2016 3:35 pm
