It is currently Fri Apr 03, 2026 12:23 am
Reply to topic  [ 3 posts ]
 gtr reverse problem
Post gtr reverse problem
After a 10 to 20 min. run sometimes I lose pressure in reverse lever and have to pump it 4 to 5 times to get pressure back. I can't find any leaks, it's a 2011 35hp. Any ideas? Thanks
Tue Nov 08, 2016 6:20 pm
Post Re: gtr reverse problem
Had the same problem with my CC. Changed the MC and didn't change anything. Ended up changing the line and caliper but if I had to bet, it was the caliper that was bad.
Tue Nov 08, 2016 8:57 pm
My 2011 did the same thing. Try changing out the brake fluid and bleeding ALL the air out afterwards for starters.
I finally ended up changing caliper and master cylinder. Could have gotten by with just the upgraded caliper.
Wed Nov 09, 2016 6:11 am
