It is currently Wed Apr 08, 2026 11:52 am
[ 3 posts ] |
rbeck
 gtr reverse problem
After a 10 to 20 min. run sometimes I lose pressure in reverse lever and have to pump it 4 to 5 times to get pressure back. I can't find any leaks, it's a 2011 35hp. Any ideas? Thanks
| Tue Nov 08, 2016 6:20 pm |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
 Re: gtr reverse problem
Had the same problem with my CC. Changed the MC and didn't change anything. Ended up changing the line and caliper but if I had to bet, it was the caliper that was bad.
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
| Tue Nov 08, 2016 8:57 pm |
ibfishinb
My 2011 did the same thing. Try changing out the brake fluid and bleeding ALL the air out afterwards for starters.
I finally ended up changing caliper and master cylinder. Could have gotten by with just the upgraded caliper.
| Wed Nov 09, 2016 6:11 am |
[ 3 posts ] |
