It is currently Sun Apr 05, 2026 4:39 pm
Reply to topic  [ 7 posts ]
 Gtr 37 efi Rpm
Post Gtr 37 efi Rpm
Does anyone know how I can set my idle higher, when the Motor is just Idling it wants to kill or is that something that has to be programmed ? ( gtr 37 efi)
Sun Nov 27, 2016 11:49 am
Post Re: Gtr 37 efi Rpm
What rpms are you idleing at?
Sun Nov 27, 2016 4:04 pm
600-700
Sun Nov 27, 2016 7:43 pm
That is a little low, mine idles around 860. I'm sure there is an idle adjustment on it, I have never had to touch mine so I won't be much help. Let me know what you end up finding out.
Sun Nov 27, 2016 8:25 pm
600-700 is low.
Take off the front cover (2 phillips head screws) and adjust the idle screw clockwise until it's running at about 950-1000 rpm.
Be careful not to pinch any wires when replacing front cover.
Sun Nov 27, 2016 8:35 pm
My 37 idles at 725 in the water, never stalled or been an issue. The idle speed should slow down as the engine warms up.
-Custom pool noodle
-stage 4 water wings
Sun Nov 27, 2016 8:37 pm
Finally got a chance to fool with my motor, open the front cover and adjusted the idle adjuster..problem solved. Thx fellas for the info
Fri Dec 02, 2016 3:36 pm
cron
