It is currently Sun Apr 05, 2026 9:58 am
[ 7 posts ] |
delacroixhunter
 Gtr 37 efi Rpm
Does anyone know how I can set my idle higher, when the Motor is just Idling it wants to kill or is that something that has to be programmed ? ( gtr 37 efi)
| Sun Nov 27, 2016 11:49 am |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
 Re: Gtr 37 efi Rpm
What rpms are you idleing at?
| Sun Nov 27, 2016 4:04 pm |
delacroixhunter
 Re: Gtr 37 efi Rpm
600-700
| Sun Nov 27, 2016 7:43 pm |
Roostertail3
 Re: Gtr 37 efi Rpm
That is a little low, mine idles around 860. I'm sure there is an idle adjustment on it, I have never had to touch mine so I won't be much help. Let me know what you end up finding out.
| Sun Nov 27, 2016 8:25 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Gtr 37 efi Rpm
600-700 is low.
Take off the front cover (2 phillips head screws) and adjust the idle screw clockwise until it's running at about 950-1000 rpm.
Be careful not to pinch any wires when replacing front cover.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Sun Nov 27, 2016 8:35 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: Gtr 37 efi Rpm
My 37 idles at 725 in the water, never stalled or been an issue. The idle speed should slow down as the engine warms up.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Sun Nov 27, 2016 8:37 pm |
delacroixhunter
 Re: Gtr 37 efi Rpm
Finally got a chance to fool with my motor, open the front cover and adjusted the idle adjuster..problem solved. Thx fellas for the info
| Fri Dec 02, 2016 3:36 pm |
[ 7 posts ] |
