It is currently Sun Apr 05, 2026 4:39 pm
Reply to topic  [ 24 posts ]
 Help!!! Mudbuddy question
Post Help!!! Mudbuddy question
Long story short I had to take my HD apart and put back together. Now my motor runs fun full throttle out of water but when it's in water under load won't go, it's like the clutch or belt is slipping. Any help would be greatly appreciated.
GD 1648 SD W/37 EFI MBHD
Wed Nov 23, 2016 7:20 pm
Post Re: Help!!! Mudbuddy question
neither one of them are probably slipping.
Going by your sig, you've got an EFI. you may have messed up something with the computer.
what exactly did you take apart on your motor??
Wed Nov 23, 2016 7:32 pm
Nothing. Just took out drive apart
Wed Nov 23, 2016 7:39 pm
does it sound like anything is slipping?
Is your motor bogging down in the water?
Is your belt tension right?
Lots of different things to check
Wed Nov 23, 2016 7:42 pm
I don't have a tension gause and I'm wondering if that is what it is. Belt is pretty dang tight though. Also, I can't hear and slipping. When it happens also, the prop is still spinning slowly put engine rpm is high
Wed Nov 23, 2016 7:47 pm
Hmm, you don't want the belt to be too tight, or it will stretch and pop. Tension guage would be best.
is the clutch tighted down and not able to slip?
Someone else here will chime in soon and help you out probably a little better than I can :lol:
Wed Nov 23, 2016 7:50 pm
Haha I appreciate the input. Clutch is tight as well.
Wed Nov 23, 2016 7:52 pm
Make sure you still have good power and ground to clutch
Wed Nov 23, 2016 11:39 pm
Possible u left a key out of pulley??
Wed Nov 23, 2016 11:46 pm
I am pretty sure all keys are back in. Just to be sure what all should be keyed? Also, I have good power and ground.
Thu Nov 24, 2016 6:35 am
Im thinking of key in lower pulley. Does the clutck make a solid click when engaged?
Thu Nov 24, 2016 11:11 am
It's keyed and yes it makes a distinct click when it engages
Thu Nov 24, 2016 1:38 pm
Just verifieng your motor free revs in water with clutch locked in...
Thu Nov 24, 2016 6:45 pm
It will push when engaging the gear but when I get in the throttle it won't go anywhere. Prop still spinning when it does this, just not very fast
Thu Nov 24, 2016 7:07 pm
Anybody else have any input on what may be going on?
Fri Nov 25, 2016 5:13 pm
Does the engine itself rev like it should and just the boat just doesn't move? (Meaning some sort of disconnect between the engine and prop?)
-Custom pool noodle
-stage 4 water wings
Fri Nov 25, 2016 5:39 pm
Yes, engine revs as it should
Sat Nov 26, 2016 3:27 am
I would open up the cover of the outdrive, engage the clutch while the engine is OFF and try to turn the prop by hand.
If the prop turns and it doesn't turn over the engine, then you have something slipping/key missing
Sat Nov 26, 2016 3:48 am
I'll try that. Thanks guys
Sat Nov 26, 2016 9:15 am
Also there is about 1/8-1/4 in gap between the front and back pieces of the clutch. I can't remember if that's normal or not.
Sat Nov 26, 2016 10:18 am
Sounds like that thing needs to find its way to a shop.
-Custom pool noodle
Sat Nov 26, 2016 11:00 am
1/8 to 1/4 sounds like alot of gap
Sat Nov 26, 2016 11:35 am
Sat Nov 26, 2016 3:59 pm
It was the clutch and I fixed it myself, but thanks for the input guys.
Thu Dec 01, 2016 9:46 pm
cron
