It is currently Tue Apr 07, 2026 11:17 am
Reply to topic  [ 11 posts ]
 Throttle cable adjustment
Post Throttle cable adjustment
I have a 35 GTR center console! I have to give it almost half throttle to get it to get out of idle! How do I adjust my throttle cable at throttle?
ALMOST DONT COUNT
Tue Dec 27, 2016 1:56 am
Post Re: Throttle cable adjustment
Ttt
ALMOST DONT COUNT
Thu Dec 29, 2016 9:52 pm
ANYONE know how to adjust the throttle cable on a center console gtr boat?
ALMOST DONT COUNT
Thu Jan 05, 2017 8:53 pm
Many of the cc throttles have more throw than they need. Judge your adjustmen from how your wide open is set. Is your wide open good? If you set yours to respond as soon as you bump up throttle, you might break cable "trying to give it more" once carb is at Wot
Thu Jan 05, 2017 9:01 pm
No it's not even close! It goes about half way up before actually revving
ALMOST DONT COUNT
Fri Jan 06, 2017 5:33 am
When the cc throttle is at wot,,, is carb getting full throttle. Dont be concerned with where it starts. Is your motor running good at full throttle??
Fri Jan 06, 2017 8:45 am
Fri Jan 06, 2017 10:39 am
Yea I don't think I'm revving all the way
ALMOST DONT COUNT
Fri Jan 06, 2017 11:24 am
But I looked at the throttle setup and it looks very intricate! I wish I knew the name brand of throttle it was
ALMOST DONT COUNT
Fri Jan 06, 2017 11:26 am
If its a stock carb you can adjust the cable at the motor, look at where the cable is mounted on rear of engine. It has a small clamp that you can loosen and adjust cable. But pay attention and do not over stretch your parts
Fri Jan 06, 2017 12:15 pm
Ok thanks fellas! I'll get it done when I get home
ALMOST DONT COUNT
Fri Jan 06, 2017 2:15 pm
