It is currently Sun Apr 05, 2026 4:08 pm
Reply to topic  [ 34 posts ]
 37 Briggs EFI Heads - 2 years since introduction - review?
Post 37 Briggs EFI Heads - 2 years since introduction - review?
Back in early 2015, the 37 EFI was introduced. At that time, we were told that the heads had a different part number from the often-maligned 35 heads that everyone complained about leaking valves on.
I would *assume* that the vast majority of 37EFI owners---PD, GTR, and MB---have not modded their EFIs with heads/tune. So what's the opinion on the "new" (if they are any different?) heads? Two years in should be enough time to tell if the heads are any different or better, right?
Tue Mar 28, 2017 6:49 am
Post Re: 37 Briggs EFI Heads - 2 years since introduction - revie
Still made by briggs. Still leak.
Tue Mar 28, 2017 7:13 am
Kool-Aid Brigade
www.southernfowler.com
Tue Mar 28, 2017 7:17 am
The only difference is the intake valve is .020 larger on the EFI. Same stuff different day!
Tue Mar 28, 2017 7:34 am
Still Chinese lowest bidder garbage. With a fancy way to squirt the gas in there...
-Custom pool noodle
-stage 4 water wings
Tue Mar 28, 2017 8:09 am
Fair enough.
Any owners here of 37EFIs that have exhibited leaking valves since 2015?
Maxxis, you work on them, correct? What have you seen?
Tue Mar 28, 2017 8:37 am
Same shit, same problems man.
Tue Mar 28, 2017 8:42 am
90% of briggs will fail leakdown test after 50-60 hours. On average I see 15-20% leakage across the board don "so called healthy motors". The owner doesn't know otherwise. The problem is the valve seats not seating square, or moving after some heat cycles. If you want to build a good engine you run it for 50 or so hours, then you pull the heads and get some good valves, Recut the seats, lap them in, and re install heads would be the BEST thing you can do for any engine.
Tue Mar 28, 2017 8:51 am
-Custom pool noodle
Tue Mar 28, 2017 10:14 am
Another 50. :lol:
Tue Mar 28, 2017 10:20 am
Kool-Aid Brigade
Tue Mar 28, 2017 10:21 am
Thanks James, I figure if it's around 200 it would be worth it.
Clay- Fah-Q :lol:
-Custom pool noodle
Tue Mar 28, 2017 10:23 am
I'm at 200 on 37 heads. Mods done at 80hrs
Sent from my SM-G930V using Tapatalk
Tue Mar 28, 2017 4:31 pm
Tue Mar 28, 2017 4:59 pm
Y'all think they're leaking?
Tue Mar 28, 2017 5:38 pm
:lol: i kid, i kid
Tue Mar 28, 2017 6:06 pm
Kool-Aid Brigade
Wed Mar 29, 2017 6:51 am
Wed Mar 29, 2017 8:02 am
So, for those that are having heads worked on....are you having B&S do it under warranty? Any preferred shops in SE Texas or SW Louisiana? Does B&S have a leak down number that they will accept for warranty? Is there any recommended upgraded metallurgy that cures the problem?
GoDevil 18X44
GoDevil 35 SD
Wed Mar 29, 2017 8:41 am
Maxxis owns bayou surface drive, he's is sw la. Can do aftermarket valves and a better fix or warranty work. Great to deal with also. His info is on the sponsors page.
Wed Mar 29, 2017 8:55 am
if I remember correct Boat Dr. said they have to leaking in the 50 to 60ish range for briggs to warranty them! Don't hold me to that.
Wed Mar 29, 2017 11:56 am
^ i knew it was crazy high. I saw someone post 90% one time but was pretty sure that was a little off. :lol:
Wed Mar 29, 2017 12:09 pm
I imagine B&S is doing some CYA with numbers so high their warranty repair rate is fairly low. I'm doing a deal on a new 35 GD SD Friday. Just wondering if I should run the crap out of it and get the hours up, then do a valve job. I don't see myself getting anywhere doing that unless B&S has a major upgrade or aftermarket has metallurgy upgrades. Then it voids the warranty, so SOL.
GoDevil 18X44
GoDevil 35 SD
Wed Mar 29, 2017 1:16 pm
Wed Mar 29, 2017 2:29 pm
honestly 65 is the number that keeps popping up in my head.
Wed Mar 29, 2017 2:37 pm
I regularly see 20%-40% leakage on these things.
Wed Mar 29, 2017 2:51 pm
Wed Mar 29, 2017 3:26 pm
I don't think I'd send the back to the manufacturer to rebuild. When they are the reason there broke.
Get a engine builder to work them. Don't have to get a crazy set. Quality will be far superior than what briggs will send ya.
Wed Mar 29, 2017 7:22 pm
I suppose I jinx'd myself..
Sun Apr 02, 2017 8:02 pm
Damn, you and James both eh?
-Custom pool noodle
Sun Apr 02, 2017 8:22 pm
Dammit man.. its usally the roller rocker motors that do that. My condolences
Sun Apr 02, 2017 8:38 pm
Heads are already at delta. She'll by running real soon!
Mon Apr 03, 2017 5:51 am
Kool-Aid Brigade
Mon Apr 03, 2017 7:01 am
