Mud Slinger
MMT Moderator
 carb icing ?
does carb icing start out right away or take time to take effect ? Friends motor ran fine one day and bad the next.
_________________ duck wacker
Mon Jan 11, 2010 11:04 am |
coastal
Joined: Wed Jan 14, 2009 8:29 am Posts: 1890 Location: South TX
 Re: carb icing ?
Mine will do it after about a 2 mile wide open run.ONLY if it is cold.I just turn it off ,smoke a cig,fire it back up and run until it does it again.
_________________ I will keep my gun's,freedom and money.You can keep your change!
Mon Jan 11, 2010 11:16 am |
jpc014
Joined: Tue Mar 10, 2009 8:17 pm Posts: 785 Location: Meraux, LA
 Re: carb icing ?
iso-heet!!!!!
auto parts store carry it and it works
HRCH Cajun Black "VOODOO" Magic 18x48 Center Console PD w/32PDHydro T&T; Hydro Reverse "If I wanted any of your lip; I would pull down my zipper"
Mon Jan 11, 2010 11:28 am |
tongthrower
Joined: Wed Jan 14, 2009 8:36 am Posts: 672 Location: Houston, TX
 Re: carb icing ?
Pull the carb heat switch out all the way...  If I remember it was the little black square... Seriously though, the only time I dealt with carb heat was with airplanes, and you could encounter it at 70deg while turning low (idle) RPMs.
_________________ EVT Stage 1 32PD on a 17x48PD "I'm not a Republican because I grew up rich. I'm a Republican because I did'nt want to spend the rest of my life poor. Waiting for the goverment to rescue me." Mike Huckabee
Mon Jan 11, 2010 12:31 pm |
balloon-knot
Joined: Wed Jan 14, 2009 9:05 am Posts: 398 Location: Prairie du Chien, WI
 Re: carb icing ?
We have had some issues with Carb icing up North here, and it ussually happens after you have ran it awhile in the cold. There seems to be a range of temp where I see it the most. Somewhere in the 10 F to 30 F range. Anything colder or warmer than that and there is not a problem. I ussuall just turn my intake on the back of my 36 to pick up warm air coming off the pipe, and that seems to help alot.
_________________ Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Tue Jan 12, 2010 7:37 am |
blairarnold
 Re: carb icing ?
I was the one who was having a problem with the carb icing. At least the way y'all describe it, that must have been what was going on. Now that the temperature has moderated I'm not having a problem with the motor cutting out, but I'm not going nearly as fast even though I'm trimming it the same way or at least am getting the same rpm's wutg the same weight load as what used to run the fastest. Does the carb icing have any residual effect?
Fri Jan 15, 2010 2:58 pm |
bluebill
 Re: carb icing ?
Stu up here in AK has come up with a nifty attachment for the air cleaner intake for the Briggs to pull warm air off the muffler. Works pretty well and a lot cheaper than the setup Briggs sells for carb iceing .
And the ambient temp doesnt have to be below 32F to get carb icing - venturi effect
Sat Jan 16, 2010 11:32 pm |
Duck Natzi
Joined: Sat Jan 24, 2009 10:14 pm Posts: 213 Location: Cervix Deep Ar.
 Re: carb icing ?
_________________ Jack Daniels Elite Pro-Staff
Sun Jan 17, 2010 1:34 am |
stumpgrinder
 Re: carb icing ?
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
Sun Jan 17, 2010 7:02 am |
Hizzoner
 Re: carb icing ?
dadgum that sounded smart.....you been hangin' with Sanders?
I've had my carb ice within a mile
Sun Jan 17, 2010 8:44 am |
stumpgrinder
 Re: carb icing ?
 Next week's lesson we'll explore integrated isenthalpic effects of isothermic coefficients and how it effects load carrying ability.
Sun Jan 17, 2010 8:50 am |
Duck Natzi
 Re: carb icing ?
call your dealer or KP @ PD your unit is still under warranty
Sun Jan 17, 2010 6:46 pm |
