It is currently Sat Mar 21, 2026 7:08 am
[ 4 posts ] |
23hp Briggs won’t run with load added to it
Gunnar3232
Need help. Mud buddy 23 runs great out of the water, but as soon as I dip the prop in the water it only idles then eventually sputters and dies. I have replaced the carb, spark plugs, checked all of the wire connections, And about everything j know to do. I thought the rev limiter might have been the problem, but I took it off, and same outcome. I got the rev limiter wet at one point and I figured that was the problem. Just wondering if maybe I shorted out the circuit breaker or something. Just need some help. Thanks!!
| Wed Feb 14, 2018 4:54 pm |
flint87
 Re: 23hp Briggs won’t run with load added to it
I can go ahead and tell you what everyone’s gona say. Check your compression and do a leak down test and go from there.
| Wed Feb 14, 2018 7:00 pm |
Russ
That sounds like it's a fuel problem.
| Wed Feb 14, 2018 7:04 pm |
Gunnar3232
Just checked and figured out I’m only running on one cylinder
| Wed Feb 14, 2018 7:22 pm |
[ 4 posts ] |
