It is currently Fri Jun 27, 2025 7:17 am
Reply to topic  [ 193 posts ]  Go to page 1, 2, 3, 4, 5  Next
 New Hybrid mud motor design
Post New Hybrid mud motor design
Ya , ya , ya
Mon Feb 08, 2010 9:48 pm
Post Re: New Hybrid mud motor design
What do you think.
Mon Feb 08, 2010 10:33 pm
looks cool. that's alot of tail to take abuse from logs and stumps.
well, get to building and show us how it does!!!!!!
good luck and watchout for the clone kings from utah.
Mon Feb 08, 2010 10:47 pm
Im curious to see if it would work.
BUCK OFAMA
Mon Feb 08, 2010 11:03 pm
ya, ya, ya, ya
Mon Feb 08, 2010 11:16 pm
well looks like it would work but, will it be a surface drive or what do you have n mind with that? is the idea the speed of an surface drive and mobility of a longtail? if so i can see how it would be benificial to produce one of them, welp good luck with this!
Mon Feb 08, 2010 11:23 pm
BUCK OFAMA
Mon Feb 08, 2010 11:29 pm
ya, ya, ya, ya
Mon Feb 08, 2010 11:32 pm
ya, ya, ya, ya
Mon Feb 08, 2010 11:42 pm
It looks like a pretty steep u-joint angle. I think I heard the Grand Munchkin say one time that 16 degrees was the magic angle on longtails.
Tue Feb 09, 2010 1:15 am
Didn't Bootzz just build sumthin like dis?
Tue Feb 09, 2010 2:05 am
If you want it to run like a surface drive the angle of the bottom shaft would need to be somewhat parallel to the surface or the whole lower unit shortened to bring the prop up to the water level? Curious.
Tue Feb 09, 2010 5:42 am
MB has had one in the works for years like that....just ask them....
Seriously though, if you have any better drawings or are serious about this project be careful where you post pics and info or somebody will copy it unless you have a patent already on it.
Tue Feb 09, 2010 6:40 am
It might work but i think that, according to your sketch, the prop can't be pushing parallel to the bottom of the boat like that because it would want to pull the motor down until it was trimmed all the way down and the transom stopped it. if you wanted to build it like that you would need some sort of trim to keep the motor up. thats why all long tails and the GDSD have the prop just about perpendicular to the joint that allows the motor to swivel up and down; to avoid the motor from creating upward or downward thrust when driving.
just my .02
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Tue Feb 09, 2010 10:36 am
Are you surface driveing the prop or not?
I can't see how your bracing it real well on my Blackberry but if your just planning to brace the out drive
Like a longtail as it appears, it aint never gonna hold up at that angle.
I would aso be concerned about that angle from the crank to the drive shaft , how well it will hold up and what kind of rpm it will take esp when under load
Tue Feb 09, 2010 12:15 pm
ya, ya, ya, ya
Tue Feb 09, 2010 12:23 pm
ya, ya, ya, ya
Tue Feb 09, 2010 12:24 pm
ya, ya, ya, ya
Tue Feb 09, 2010 12:26 pm
ya, ya, ya, ya
Tue Feb 09, 2010 12:28 pm
ya, ya, ya, ya
Tue Feb 09, 2010 12:38 pm
ya, ya, ya, ya
Tue Feb 09, 2010 12:49 pm
belt + CV / U Joints + Gears + steep driveline angles = maintenance nightmare!
udder den dat, good luck ;)
Tue Feb 09, 2010 12:53 pm
You are creating a huge torque arm with the extending the prop in that manner. The transom bracket will have to be larger than most are today to disipate all of that energy.
I think you are going to have troubles finding a u-joint or a CV joint that will run at those angles for lon periods of time (i.e. thier entire life)
You may want to look in the direction of bevel gears that way you do not need the belt to incorporate the gear reduction. Oh wait, then you will have a PD.
Just kidding,
Keep working on it, you will find something that works.
Mag10
Tue Feb 09, 2010 1:01 pm
Tue Feb 09, 2010 1:05 pm
I think that Crews will love this guy........forsure
Tue Feb 09, 2010 1:10 pm
ya, ya, ya, ya
Tue Feb 09, 2010 1:11 pm
ya, ya, ya, ya
Tue Feb 09, 2010 1:16 pm
:lol: Well dat is good news.
Tue Feb 09, 2010 1:19 pm
ya, ya, ya, ya
Tue Feb 09, 2010 1:21 pm
ya, ya, ya, ya
Tue Feb 09, 2010 1:23 pm
ya, ya, ya, ya
Tue Feb 09, 2010 1:26 pm
ya, ya, ya, ya
Tue Feb 09, 2010 1:37 pm
2060 CC 3/4 Gator-tail 1/4 Brother Breaux Boat /35GTR
Cowboy thought- a thong on a woman is like a barbed wire fence. It protects the property but doesnt obstruct the view.
Tue Feb 09, 2010 1:43 pm
ya, ya, ya, ya
Tue Feb 09, 2010 2:15 pm
Tue Feb 09, 2010 2:26 pm
What is the operating range in respect to angles of the cv and universal joints that you have sourced?
Tue Feb 09, 2010 2:36 pm
us mechanics love de hell out of engineers :mrgreen:
Tue Feb 09, 2010 3:13 pm
Tue Feb 09, 2010 3:15 pm
Hopp-
You sound like a total schmuck. Even if you are in engineering school, that doesn't make your idea realistic. And even at that, what school do you go to? Basically it looks like your trying to take a longtail and complicate the design. You said it yourself; If the angle is to severe, you will extend the wheel further back.
Tue Feb 09, 2010 3:23 pm
I think that the CV idea will work just fine. For you non believers there are CV's out there that are capable of 42 degree operating angles.
Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Tue Feb 09, 2010 4:24 pm
Users browsing this forum: Google [Bot] and 118 guests
