It is currently Fri Jun 27, 2025 2:44 am
Reply to topic  [ 9 posts ]
 Mikuni Jet Needle removal ??????
Post Mikuni Jet Needle removal ??????
How do I move the Jet Needle up one notch I removed the idle adjuster screw and have the top cover off I could also loosen the alen head and move the retainer butI cant figure out how to get the needle out the damn throtlle linkage is in the way and it says not to remove it so How on do I get the needle out and move it up one notch Thanks :x
Wed Feb 17, 2010 6:29 pm
Post Re: Mikuni Jet Needle removal ??????
http://www.sbtontheweb.com/pdfs/mikunisbn.pdf
Wed Feb 17, 2010 6:42 pm
That looks nothing like what im lookin at on my 42mm MikuNI Im looking down from the top and I can see the jet needle but cant get to it without removing the Throttle lever linkage and I dont want to do that
Wed Feb 17, 2010 6:54 pm
I want to say you can screw out on the idle adjuster knob to reach the allen head to loosen it, but to get it out I back the throttle lever stop scew out, its on the left side the carb ( opposite side of the throttle cable linkage) theres a locking nut on it. Can't miss it. that will allow you to rotate the slide/gate and linkage up more and out the way enough to reach in there with a set of needle nose pliers.
Make sure to count the turns when you back it out, That way you can go back to the factory setting.
Page 17
http://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
Wed Feb 17, 2010 7:02 pm
Thanks for the quik help got it moved Ill run it tomorrow to see if it helped
Wed Feb 17, 2010 7:35 pm
Loosen the allen head, move the black clip to the side, open the throttle wide open and the needle will come up enough for yu to grab it.
Wed Feb 17, 2010 9:26 pm
Just so I dont go the wrong direction on the Jet needle I want to richen it up so that means I put the C clip one notch down correct. It was on the 3rd on down no is on the 4th
Thu Feb 18, 2010 6:45 am
Correct. You are moving the needle up which allows more fuel to move out of the tube therefore you would have to lower the clip.
Thu Feb 18, 2010 6:50 am
Thu Feb 18, 2010 8:52 pm
Users browsing this forum: No registered users and 58 guests
