It is currently Thu Jun 26, 2025 10:07 pm
[ 6 posts ] |
Running a Surface Drive or a Longtail on a TUNNEL hull?
DaveSturkey
I have an 18 foot Sea Ark with a tunnel hull. I'd like to run a surface drive, but am thinking that the tunnel might hurt the performance. I called Sea Ark and they said that it should NOT effect negatively performance.
Is anyone running a rig like this?
Thanks,
Dave
Sun Feb 21, 2010 2:30 pm |
idabilly
Joined: Sat Jan 17, 2009 7:17 pm Posts: 617 Location: Idaho
 Re: Running a Surface Drive or a Longtail on a TUNNEL hull?
The tunnel won't help you at all. It might hurt you. Worst case, if you love the boat just seal up the tunnel.
Sun Feb 21, 2010 3:13 pm |
stumpgrinder
either da morons at Sea Anchor aren't really sure how a tunnel is supposed to work..... or dey ain't really sure how a MM works. Either way they're wrong.... sure it'll work but not worth a damn.
Either close da tunnel up and then put a MM that corresponds with da transom height once da tunnel is closed.... or just get rid of it completely and get a rig better suited for a MM to begin with.
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
Sun Feb 21, 2010 6:50 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
Should we start at this one again stumpy or let it be?
_________________ BUCK OFAMA
Sun Feb 21, 2010 7:40 pm |
deadbird8
Have to use a longer outdrive with it to get the best performance but its definitely not the best set up.
Sun Feb 21, 2010 8:35 pm |
Gatorpoint
Joined: Tue Jan 13, 2009 8:09 pm Posts: 1175 Location: A slough behind you, TEXAS
A buddy of mine has a Gatortrax hyper tunnel and tried to run a PD on it and it sucked. The tunnel threw water right into the gear knuckle. SD mud motors are supposed to run on top of the water not through the water column created by how a tunnel works. He filled in the tunnel and his rig does well now.
_________________ 1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh! Willett Welding custom boat trailer
Sun Feb 21, 2010 9:51 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 126 guests |
