It is currently Sat Dec 20, 2025 7:50 pm
Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
 Trailer not pulling right
Post Trailer not pulling right
Have a McClain trailer and never had an issue. Recently its all over the road when I get around 60-65. All variables look normal and can't see that anything has changed with my setup. Hub bearing changed last yr and look to be ok, boat sitting in same spot on trailer, tires good and air pressure the same. I can't figure it out. Used to be able to run the interstate at 80 but now the bastard wants to sway and run all over the place. Any ideas?
1850 & 36pd
Tue Jul 29, 2014 8:26 pm
Post Re: Trailer not pulling right
tires? I had a trailer tire start separating (looked fine) that acted like that.
Tue Jul 29, 2014 8:30 pm
Might be in a bind... check the axle and make sure its square.. you may have hit a pot hole or somthing and threw it off a smidge..
Tue Jul 29, 2014 8:42 pm
Sound like something got knocked out of whack. More than likely the axle alignment.
Tue Jul 29, 2014 8:56 pm
Those McClain trailers have u bolts on everything. Do you think maybe the axle slid back a little? Or to the side? Got to be something like they saying above. Maybe bent a spindle
Dead Fowl Custom 1954hd with a GTR
Tue Jul 29, 2014 9:00 pm
Haven't been any bad roads lately but something has happened for sure. Springs seem to be ok. Im going to get a tape and measure everything in the morning.
1850 & 36pd
Wed Jul 30, 2014 12:11 am
You pulling the trailer with the same vehicle? If so axles must a little out. It doesn't take much.
Excel 1851vF86 w/ MB 55V
SHIT HAPPENS
Wed Jul 30, 2014 5:38 am
Have you changed the load at all? The tongue weight or more importantly lack of tongue weight can cause a trailer to track poorly.
Wed Jul 30, 2014 6:38 am
make sure the axle is square. if so jacks the trailer up and push and pull on the tire to see if you have slack in the spindles
Wed Jul 30, 2014 6:41 am
Try changing our one tire at a time with your spare. If it was an axle alignment issue I'd think it would do it at slower speeds. I'm leaning toward a tire issue.
Wed Jul 30, 2014 8:00 am
MSM
When your truck loses alignment when do you notice it first
Wed Jul 30, 2014 8:15 am
Never happened....it's just something else to try that's pretty easy.
Wed Jul 30, 2014 8:26 am
You have never had a vehicle that pulls at any point in life
Wed Jul 30, 2014 8:32 am
Preventive maintenance son.
Wed Jul 30, 2014 8:50 am
"pulling" on most vehichles is caused by worn parts/tires ect - off alighment is mostly drifting and steering wheel off center to correct alighment and abnormal tire wear.
if trailer "tape measures out square" and no visible worn misaligned pieces parts, check them tires pretty close
Wed Jul 30, 2014 9:05 am
lol. I drive average of 1000 miles a week. It's inevitable
Are the tires wearing abnormally?
We had a McClain and it was wearing tires very quickly.
Axle looked fine to the eye so we thought everything fine with axle and couldn't figure it out.
Turned out the axle was slightly bent when you put a straight edge on it.. Bent right in the middle and couldn't really see it just looking at it especially trying to look with boat on trailer.
Good luck. Let us know what you find out.
Wed Jul 30, 2014 9:16 am
Wed Jul 30, 2014 10:37 am
Wed Jul 30, 2014 11:02 am
Wed Jul 30, 2014 2:00 pm
Wed Jul 30, 2014 5:44 pm
Its possible I guess. Those ultras go down pretty quick on a hot afternoon...lol. Looked at it and found a bad spot on the inside of one of my tires. Its a junker Carlisle tire and im pretty sure that its the culprit. Gonna put a new set on and see how it runs..
1850 & 36pd
Wed Jul 30, 2014 11:24 pm
Thu Jul 31, 2014 1:21 am
That's impossible....duckduckboom said it was an alignment issue.:lol::lol:
I would still check everything. What caused it?
Probably the shitty ass Carlisle but I would stil check.
Thu Jul 31, 2014 5:56 am
The proper way to check axle alignment is to:
1. Take tires off.
2. Turn hubs till a stud is in the most forward position towards the tounge.
3. Measure from that stud to the inside of the trailer coupler(the piece that moves)
Measure both sides and they should be the same if it's aligned.
I just built a trailer and that's how I was told to do it.
Thu Jul 31, 2014 7:09 am
Cool thx for that info msm. Im going to check it after this rain.moves on.
1850 & 36pd
Thu Jul 31, 2014 9:28 am
Thu Jul 31, 2014 5:47 pm
Any luck?
Mon Aug 04, 2014 6:22 am
The tongue is heavy. I haven't moved anything. Everything measured out good. Been working a lot of ot before we head out on vacation so I haven't messed with it any. Gonna pick up a tire this week.
1850 & 36pd
Mon Aug 04, 2014 11:13 am
There's been a lot of that lately...
Folks get on here with a problem, get all sorts of suggestions and gains curiosity of others, just the hear "I've been busy, haven't had time to mess with it". Well kiss my ass! :lol:
Mon Aug 04, 2014 12:47 pm
:lol:
Mon Aug 04, 2014 12:53 pm
Man working 7p-7a everyday its really to say "phuck that trailer" and walk in the house and go to sleep :D
1850 & 36pd
Mon Aug 04, 2014 2:49 pm
I don't want to hear it! :lol: pm to am means you got all day to look at it, not like its too dark! :lol:
Mon Aug 04, 2014 2:59 pm
Mon Aug 04, 2014 3:18 pm
Damn right!! I want to know!! :lol:
Mon Aug 04, 2014 3:23 pm
Tue Aug 12, 2014 5:04 am
Lol, Charley wtf was wrong with ya trailer!! Will really wants to know!
1754 GTB / 35 GTR
Tue Aug 12, 2014 5:47 am
Lol
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Aug 12, 2014 5:48 am
