It is currently Sat Jul 05, 2025 3:56 am
Reply to topic  [ 93 posts ]  Go to page Previous  1, 2, 3  Next
 outboard leg mud motor(now running 26 briggs)
Post Re: outboard leg mud motor
Throttle and manual choke done.
Engine required 1 inch of stroke from idle to wot,control box has 2 1/4 travel.so i added an extension arm to put engine throttle trave to 2 1/4.
Wed Oct 14, 2015 7:52 pm
Ugly loud mower exhaust done
Wed Oct 14, 2015 8:33 pm
Post outboard leg mud motor
Wed Oct 14, 2015 8:48 pm
The oil filter is pretty dead.
Cant wait to run her this weekend.
Ill make a vid.....slow or fast....im happy.
Wed Oct 14, 2015 8:54 pm
Man thats slick work.
Thu Oct 15, 2015 8:54 am
Thanx
I think its turning out alright sofar.
Thu Oct 15, 2015 2:19 pm
Its a mess at the moment,but power trim working from control box,starter turns with key.
Only kill wire and charging wire left.then tidy up.
Thu Oct 15, 2015 7:39 pm
Bout as meat as im gonna get it for now.
Everything works from control box except choke.
All she needs is fuel and test ride.
Thu Oct 15, 2015 8:34 pm
Please change that damn oil before you run it. It takes 5 minutes and about 10$. Sure would hate for you to burn up the engine on your first outing because of something preventable
1542 War Eagle with 25hp GDLT
Fri Oct 16, 2015 7:22 am
Im kinda attatched to the old oil and beat filter.
Its in the works,test run on land this evening followed by engine service.
Fri Oct 16, 2015 8:34 am
Looking good. Keep us posted, I can't wait to see how it does.
Fri Oct 16, 2015 7:25 pm
Will do jc
Just fired the beast up,everything working as it should.didnt rev over 1500 rpm though....my kids are watchin a movie inside.
I almost wanna go launch her tonight....lol.
Muffler is pretty quiet....but produced alot of radient heat in 1 min running ....6 in away....couldnt stand to keep my hand near it.
Im fearing shes clogged up.
Fri Oct 16, 2015 7:34 pm
Dug threw my props....i have a 35 merc 16 pitch,a 40 mariner magnum 15 pitch and the stock yamaha 50 15 pitch.
Ill try them all tomorrow.
Fri Oct 16, 2015 8:04 pm
Post Re: outboard leg mud motor(now running 26 briggs)
Oil and filter changed,all i could find was a phram for a 19 intek.
Online states 18-26 intek take the same filter.went on no issues.
Fri Oct 16, 2015 9:43 pm
Definitely run that thing and take a vid.... Curious to see how it does. I feel like all those props are going to be too steep for that motor.
Sat Oct 17, 2015 11:47 am
Test ran some more,bout to launch in all this wind.
Adjusted govoner,but if i go higher my idle raises up.so im limited to about 2800 rpm at the moment.
Sat Oct 17, 2015 11:56 am
18-20 mph with 50 wheel,gotta move shift linkage 1/2 further back...stays in foward when control box in neutral.
The other wheels are too small.
This govner only hittin around 2500 loaded wot 2600 no load.....nowhere near where i wanna be.
I wanna work the bugs out before gettin a vid.
Plus its really windy puttin a dent in my speed.
Lots of lowend torque...i love it
Sat Oct 17, 2015 1:03 pm
Nothing fancy....but heres a vid for all the doubters....lmao.
Watch "26 briggs ontop 50 yamaha" on YouTube
https://youtu.be/NgYEhlA4cSw
Sat Oct 17, 2015 1:51 pm
It seems once you get your rpms up youll be flying! Nice build!
Sat Oct 17, 2015 4:54 pm
Thanx
Done few more runs,adjusted govner and throttle.
I had my dad drive...i pulled govner....it was maxed out already.
I think my boats just too heavy.
70 johnson only pushed it 31-34 mph at 5400 rpm.
But with 2 people i actually got up to 24 mph with my dad on the bow.still not bad considering the frankenstein build.
Lots of tweakin to do....but i think i need a lighter boat to hit 30 plus mph.
Sat Oct 17, 2015 5:32 pm
Took her on a 15 mile cruise today,around bourg area,upper bayou terrebonne,intercoastal.
All went well untill i headed back to boat launch.fuel problems,anything past half throttle id run outta fuel within a few seconds.swapped fuel pumps...same result.im assuming my old fuel hose and primer bulb is the culprit.
Burned 3 gal of gas today just playin around.
Sun Oct 18, 2015 4:18 pm
Sun Oct 18, 2015 6:09 pm
im currently considering running the smaller wheel,i have a bps 4470-4670 limiter.....trying to research if the intek can handle that kinda rpms though.ive read anything over 4300 rpm requires valve spring shims or tighter springs.
but that info was on a 23 vanguard.....my understanding the intek series is a cheaper engine.
i posted questions in engine mod.
Sun Oct 18, 2015 6:15 pm
I think it's great results for what its made from,I don't think pure mud is an option however shallow water runningwould not
Be an issue.maybe less prop pitch is the way to go.Perhaps raising the motor about an inch above the transom might help.
Mon Oct 19, 2015 6:47 am
Mon Oct 19, 2015 7:08 am
I can lift motor upto 2.5 inches using factory bracket bolt holes.
Run her surface drive with current wheel,and govner work.
Currently my cavitation plate is 1/2 in higher that bottom of boat.
Mon Oct 19, 2015 8:36 am
I say raise her up and give it a try.
Mon Oct 19, 2015 10:09 am
Sounds like a good plan,step her up 3/4 in at a time.
This is the moment when a jack plate would be handy.
Mon Oct 19, 2015 10:16 am
Redlined suggested a lawn mower forum....full of racin fanatics that hop up intek engines.....ill be hangin out over thete for a lil while researchin.
Ive also got work lined up this weekend....so dont expect updates.....but stay tuned.hopefully my next vid will be more impressive.
Honestly im impressed with 20-25 outta this rig.
My intention with this build started out as a sliw motor to push around my 18ft camp boat.
Tue Oct 20, 2015 6:47 pm
The heymow forum has a dedicated place for briggs v twins,all race mod talk.those guys are nuts about performance.
Tue Oct 20, 2015 7:39 pm
yeah...i just read they run the 20-26 inteks (44ci) upto 8k rpm loaded during a 1 hour race.....mind blowing.
shaved heads,billet rods....ect.
were talking 60 hp small block briggs that can last 50 1 hour races.
imagine what those mods can do for a mudmotor.
Tue Oct 20, 2015 8:10 pm
The racing mower forum hasnt been helpful.....if its not going on a racing mower,and being run in a sanctioned race,they wont help or offer info.
But they have impressive builds and results.
Acording to their builds ,$2000 on my engine will give her 50 reliable hp at 7k rpm.
Thu Oct 22, 2015 11:34 am
I had a blown intake gasket.....and fuel hose too long,pump too weak to supply fuel to carb at full theottle.
Last run i kept running out of fuel.
Im gonna break 30 mph....stay tunned.
Fri Oct 23, 2015 9:32 pm
That will really cause problems. Should be a big improvement with the leak fixed and new pump.
Sat Oct 24, 2015 11:43 am
Went see 2 feathers,the attractive woman behind the counter gave me 2 used gaskets.....ordering new ones.hopefully tomorrow i can install them.
Sun Oct 25, 2015 12:01 am
Went take her a good 6 hour ride saturday in the rain.i have hovner set pretty low.....1600 rpms wot about 18 mph,my boat is just too heavy to get any speed from this setup.
My hull weights around 1000 or better.
Its a 1754 duracraft bass boat.new from factory its a 1400 lb hull....but i removed all under floor foam and both livewells,along with console storage.
Im rear heavy with either motor.
So for now this will be a slow cruiser untill i can get a lighter boat.....or another 26/50 yami motor to add to it....lol.
Id really like a 40hp vertical shaft.
Tue Nov 03, 2015 7:09 pm
Put a kawasaki on it
Tue Nov 03, 2015 7:31 pm
Believe me...id love to
But im flatbroke,barely makin ends meet at the moment.
If i had the cash id invest in this rig,electric fuel pump,bigger better motor,custom prop,home made ultrajack....ect.
Tue Nov 03, 2015 7:46 pm
I get alot stares and compliments on this motor.
Finally installed a mr gasket #42s 2-3.5 psi electric fuel pump,settled for the slower 35 merc wheel and lowered govner a lil bit.the result is slower topend but better lowend and cheap on fuel.1 gal of gas gives me 2.5 hours full throttle runs.
My power trim motor took a crap,so ive been avoiding shallow stuff.
Watch "Homemade outboard motor" on YouTube
https://youtu.be/8oJngqX6XTA
Sat Apr 09, 2016 7:27 pm
Man that thing is awesome. Good job on getting all that synched together. Looks like your moving pretty good too, did you GPS the speed in that video?
Sun Apr 10, 2016 7:49 am
Users browsing this forum: No registered users and 58 guests
