It is currently Fri Jul 11, 2025 9:50 pm
[ 9 posts ] |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
 PD Lower Unit Grease
How often do you grease the newer style Prodrive lower units? Specifically the zero right above the cav plate that makes grease come out by the prop.
Wed Jun 05, 2013 6:53 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: PD Lower Unit Grease
i grease mine often.. i run alot of lillies that get stuck around the prop and cut the seals
every time i pump grease water comes out... even after the first ride
_________________ I gave up mud motors
Wed Jun 05, 2013 7:38 pm |
K'jun
Joined: Sat Mar 02, 2013 12:40 pm Posts: 47 Location: Deep South, LA
This is a stupid question, but do you pump in that grease sert till grease comes out by prop? If not how many shots do you pump in at a time?
Wed Jun 05, 2013 8:17 pm |
T-Bubba
i pump it till grease comes out a good bit to flush it
Wed Jun 05, 2013 9:35 pm |
Will
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Thu Jun 06, 2013 3:41 am |
K'jun
So I'm assuming here, theres no seal around the prop shaft that will be blown out if i keep pumping grease till i see it?
Thu Jun 06, 2013 6:26 am |
Will
Correct
Thu Jun 06, 2013 6:28 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
There are seals around the prop shaft, but they won't get blown out when u squeeze it.
_________________ 18'x54"CC Hanko/ 36PD
Thu Jun 06, 2013 2:01 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
I purge mine every 50 hrs or so, by removing the bottom plug on the prop shaft and pump grease until it comes out clean.
Fri Jun 07, 2013 10:17 am |
[ 9 posts ] |
Users browsing this forum: No registered users and 53 guests |
