It is currently Sat Jul 12, 2025 1:49 pm
Reply to topic  [ 9 posts ]
 PD Lower Unit Grease
Post PD Lower Unit Grease
How often do you grease the newer style Prodrive lower units? Specifically the zero right above the cav plate that makes grease come out by the prop.
Wed Jun 05, 2013 6:53 pm
Post Re: PD Lower Unit Grease
i grease mine often.. i run alot of lillies that get stuck around the prop and cut the seals
every time i pump grease water comes out... even after the first ride
I gave up mud motors
Wed Jun 05, 2013 7:38 pm
This is a stupid question, but do you pump in that grease sert till grease comes out by prop? If not how many shots do you pump in at a time?
Wed Jun 05, 2013 8:17 pm
i pump it till grease comes out a good bit to flush it
Wed Jun 05, 2013 9:35 pm
Thu Jun 06, 2013 3:41 am
So I'm assuming here, theres no seal around the prop shaft that will be blown out if i keep pumping grease till i see it?
Thu Jun 06, 2013 6:26 am
Correct
Thu Jun 06, 2013 6:28 am
There are seals around the prop shaft, but they won't get blown out when u squeeze it.
18'x54"CC Hanko/ 36PD
Thu Jun 06, 2013 2:01 pm
I purge mine every 50 hrs or so, by removing the bottom plug on the prop shaft and pump grease until it comes out clean.
Fri Jun 07, 2013 10:17 am
Users browsing this forum: No registered users and 75 guests
