It is currently Sun Jun 22, 2025 11:57 pm
Reply to topic  [ 12 posts ]
 18x54 GTB with 35GTR
Post 18x54 GTB with 35GTR
well yesterrday i was able to pick up my boat from gator tail. I put it in the water about an hour later and i love it. It is the extreme hull and handles very well. It has hoyt's stage 1 (cam, heads, exhaust). When i took it out it was me (240lbs) and a buddy (150lbs) 9 gallons of gas trolling motor with battery ice chest with budlight and the normal boating stuff. I was only running 26 bumping 27 @4150rpm, same stuff in the boat and just me 28 bumping 29at the same rpm. i think i should be getting a little more out of it I have seen the same size boat on here with stock motor on here running the same speed. thanks in advanced.
Fri Jun 07, 2013 12:27 am
Post Re: 18x54 GTB with 35GTR
Turn your gov up until you at the rev limit or max out
Fri Jun 07, 2013 12:59 am
- Mark Twain
Fri Jun 07, 2013 6:31 am
I have done that already the best speed I get is @ 4150rpm. The prefilter is gone also, and it also backfires when revving down. Is that normal?
Fri Jun 07, 2013 11:10 am
What octane fuel are you running? Also you have to think about how much boat sits in the water. I have a 17x54 gtb and can bump 30 by myself(when I can keep the bow from bouncing). My buddy had a 18x48 build by Uncle-J with a 7.5 ft rake, he doesn't have much sitting in the water once he gets on plane. He has less drag and weight than what I have and stays infront and gets on plane quicker(maybe 20 yards in front).
17x54 GTB with 35hp GTR
Fri Jun 07, 2013 5:32 pm
I run 93 and it's gets on plane very quick and has loads of power down low. Would a carb help me with top end? It's it worth the money?
Fri Jun 07, 2013 9:01 pm
Yes if you have the extra cash...not worth it if you dont.
Fri Jun 07, 2013 9:06 pm
If u have cams heads and exhaust those speeds r horrible
Fri Jun 07, 2013 10:19 pm
It's only had about 5 hours on it when I got the speeds, will it get better after it breaks in? Should I just call Hoyt and tell him what's going on and go from there?
Sat Jun 08, 2013 11:24 am
Sat Jun 08, 2013 12:53 pm
Sat Jun 08, 2013 2:23 pm
Yeah. Just me in my boat I bump 29 bone stock. And I have a console rig. Something isn't right
1854 Extreme CC 35 GTR
RTR!!!
Sat Jun 08, 2013 3:11 pm
Users browsing this forum: Google [Bot] and 66 guests
