It is currently Sun Jun 22, 2025 11:36 pm
Reply to topic  [ 11 posts ]
 Advice Needed
Post Advice Needed
I have 17/52 excel with MB 35 Mini on it. When out of the water or stopped motor will turn with ease. When running my motor will absolutely wear you out tryin to turn. Its all I can do sometimes to straighten out. You guys have any idea what might cause this and any advice how I can resolve the issue. Thanks in advance.
Sat Jun 08, 2013 6:55 am
Post Re: Advice Needed
Have you greased everything , what do you have in the back of the boat ie fuel cell, battery ? Have you played with the trim angle while running?
Semper Fi
16x38 WC Skiff 35 MB HD
Sat Jun 08, 2013 7:04 am
Yeah everything is Greased, battery in the back. I will add my boat has full floatation and is very heavy. I've just noticed when riding with buddies it's like being on vacation if I run there rig.
Sat Jun 08, 2013 7:09 am
Weight placement can make a huge difference. Put the battery up front and see what that does. Mine has a "sweet spot" on the trim . Do you have it trimmed too far down???
Semper Fi
Sat Jun 08, 2013 8:17 am
Sounds like its running too deep.
Sat Jun 08, 2013 10:02 am
What length drive do you have?
Sat Jun 08, 2013 11:41 am
You talking about trying to turn under full power? If so let off a little and then when you get it back around get back in it....also when turning towards yourself thats the nature of owning a mudmotor, sharp turns will put you to work, its worse in mud
Sat Jun 08, 2013 5:51 pm
sell it get a pd
- Mark Twain
Sat Jun 08, 2013 7:53 pm
Is it fighting you even when driving straight or only when turning is it difficult?
What size shaft are you running? 27,32
2014 Pro Drive Gen 3
2014 17x54 X-Series
Sun Jun 09, 2013 12:37 am
As long as the weight is balanced good it doesn't fight while running. 32 inch shaft. Getting into a turn is no problem. Coming out of it is where my problem is.
Sun Jun 09, 2013 8:19 pm
That's normal, with GT, GD, MB, only motor I have driven that is alittle smoother in the turns is the PD. Reason being is it has more weight hanging off the transom, skeg design plays a part
Sun Jun 09, 2013 11:13 pm
Users browsing this forum: No registered users and 57 guests
