It is currently Sun Jun 22, 2025 10:08 am
Reply to topic  [ 8 posts ]
 GDSD 35
Post GDSD 35
I have a question that i hope someone can answer. Underneath the prop is a fin that is bent slightly to the side. What is that for? It has moved all the way over and i have seen a decrease in speed . any help is appreciated.
SENT VIA HOOT OWL!
I drive a Godevil and don't give a shit about your message!!!
MeatWagon
GoDevil 35 Surface Drive on a 13x60 MaxCraft AIRBOAT HULL!
Wed Mar 16, 2011 1:48 am
Post Re: GDSD 35
SENT VIA HOOT OWL!
MeatWagon
Wed Mar 16, 2011 2:33 am
Post Re: GDSD 35
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Wed Mar 16, 2011 7:08 am
Post Re: GDSD 35
The bend in the verticle fin below the prop is to offset prop torque.....
Really doubt that bend has changed any though - more likely you
are getting some prop wear from that neked mud runnin' ! ! !
On a new 3 blade GDSD prop the blades measure 3 1/2" across in the
widest or fatest part of the blade - the first little bit of wear actually
makes you run faster - but when the wear gets worse and your
blade gets to 3 1/4" across it begins to loose speed and performance
and at 3 1/8" you will be over reving and bumping the rev-limiter all
the time....
When they are less than 3 1/4" - you need a new prop...
Eat - Sleep - Hunt ! ! !
Wed Mar 16, 2011 7:14 am
Post Re: GDSD 35
SENT VIA HOOT OWL!
MeatWagon
Wed Mar 16, 2011 12:36 pm
Post Re: GDSD 35
SENT VIA HOOT OWL!
MeatWagon
Wed Mar 16, 2011 12:37 pm
Post Re: GDSD 35
that needs to have a bend in it. the pd has a wedge welded to the skeg for the same reason
Wed Mar 16, 2011 2:16 pm
Post Re: GDSD 35
so you wont be sitting there holding it towards you
TRYIN' TO LEAVE A CARBON FOOT PRINT!
BUMMIN RIDES AT THE MOMENT, UNDER CONSTRUCTION!
Wed Mar 16, 2011 4:19 pm
Users browsing this forum: No registered users and 53 guests
