It is currently Sat Jun 21, 2025 9:19 pm
[ 8 posts ] |
MeatWagon
 GDSD 35
I have a question that i hope someone can answer. Underneath the prop is a fin that is bent slightly to the side. What is that for? It has moved all the way over and i have seen a decrease in speed . any help is appreciated.
_________________ SENT VIA HOOT OWL!
I drive a Godevil and don't give a shit about your message!!!
MeatWagon GoDevil 35 Surface Drive on a 13x60 MaxCraft AIRBOAT HULL!
Wed Mar 16, 2011 1:48 am |
MeatWagon
 Re: GDSD 35
Wed Mar 16, 2011 2:33 am |
mcnemar1982
Joined: Mon Jan 19, 2009 4:03 pm Posts: 2216 Location: Walker, Louisiana
 Re: GDSD 35
_________________ Ideas not coupled with action never become bigger than the brain cells they occupied.
Owner DEEP SOUTH CUSTOM BOATS (225) 252-2700 Good boats ain't cheap, Cheap boats ain't good!
Wed Mar 16, 2011 7:08 am |
Gigafowl
 Re: GDSD 35
The bend in the verticle fin below the prop is to offset prop torque.....
Really doubt that bend has changed any though - more likely you are getting some prop wear from that neked mud runnin' ! ! !
On a new 3 blade GDSD prop the blades measure 3 1/2" across in the widest or fatest part of the blade - the first little bit of wear actually makes you run faster - but when the wear gets worse and your blade gets to 3 1/4" across it begins to loose speed and performance and at 3 1/8" you will be over reving and bumping the rev-limiter all the time....
When they are less than 3 1/4" - you need a new prop...
Wed Mar 16, 2011 7:14 am |
MeatWagon
 Re: GDSD 35
Wed Mar 16, 2011 12:36 pm |
MeatWagon
 Re: GDSD 35
Wed Mar 16, 2011 12:37 pm |
autogateman
 Re: GDSD 35
that needs to have a bend in it. the pd has a wedge welded to the skeg for the same reason
Wed Mar 16, 2011 2:16 pm |
Cammander26
 Re: GDSD 35
so you wont be sitting there holding it towards you
_________________ TRYIN' TO LEAVE A CARBON FOOT PRINT! BUMMIN RIDES AT THE MOMENT, UNDER CONSTRUCTION!
Wed Mar 16, 2011 4:19 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 50 guests |
