Podcast
Joined: Fri Dec 09, 2011 12:33 pm Posts: 1363 Location: Friggin cold up here
 Update- 1842 & 27 PD
Rehash: got 20 bumpin 21 just me @ 3400 rpm. Played with carb linkage and got 20 bumpin 21 with my ol man and me @ 3510 rpm. Didn't know if it was the linkage adjustment or the boat ridin more level.
New update: went out today after setting the throttle linkage to engage immediately when you twist the throttle. Before it would engage after about 1/3 throttle. After I did that I checked to see when the carb plate fully opened. It was 100% open at half throttle. So I think should give me max rpm at half throttle. Start it up in the parking lot. Sure nough, 4250 at half throttle twist. So I take er out. I'm hitting 22 bumpin 23 at 3650. Now here's the really funny deal. That was at full twist. The carb fully opens at half twist. So I thought after a couple minutes let of to half throttle since it should run the same. Well immediately after lettin off it lost rpm. So between 100% down to 50% throttle I was loosing rpm. But the plate is fully open at 50% rpm. What gives y'all?
_________________ Wildberry "Between You, Will, DUCK HEARSE, and PODCAST I have trouble reading anything on here" 23GTR stage 2 by Calen pushin a 1746 Kliebert
Mon May 28, 2012 8:12 pm |
Woodiebuster
 Re: Update- 1842 & 27 PD
A motor wraps up faster when there is no load on it.
Mon May 28, 2012 9:00 pm |
Podcast
Tue May 29, 2012 6:58 am |
Podcast
Looked closer tonight. Took a nut out blockin the throttle linkage plate from turnin. Got 3800 at 23 mph with me, my boy-75 lbs, my ill gal-55 lbs, and my dog-65 lbs. I'm good with that. Lookin forward ta runnin er myself.
Tue May 29, 2012 6:04 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
def. should turn 25 with just you. Get those heads done and you are gonna have a really nice rig I do believe. BTW, what is a 120# control unit?
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Tue May 29, 2012 6:20 pm |
cb5331
Tue May 29, 2012 6:35 pm |
Podcast
Thanks Clay. Yup. You got er.
Heads will be done in a month er two. Lookin forward ta that!
Tue May 29, 2012 6:58 pm |
Team Camo
I think you kinda misunderstood what Woodie was sayin. The motor aint gonna turn up the same rpm under a load that it will in neutral. Think about it like your truck. With just you & a 12 pk of beer, it'll peg out the speedo, but put a load back there like a big tractor or something heavy, & you can give it all the throttle you want. If the horsepower aint there, the rpm's won't be either.
Tue May 29, 2012 8:08 pm |
Podcast
Understood TC. Maybe I did a chit job a explainin it. Ta break er down simple, none a the linkage was adjusted right all between the throttle rod and the carb.
Wed May 30, 2012 6:03 am |
Podcast
Final update. Ran er tonight and bumped 25 and steady 24.
Gps said 29 at one point but darn sure that was a glitch.
Sat Jun 02, 2012 9:34 pm |
mizzippi jb
dang right! Getting it where you wanna be.
Sun Jun 03, 2012 5:41 am |
