It is currently Tue Jun 24, 2025 11:20 pm
Reply to topic  [ 11 posts ]
 Update- 1842 & 27 PD
Post Update- 1842 & 27 PD
Rehash: got 20 bumpin 21 just me @ 3400 rpm. Played with carb linkage and got 20 bumpin 21 with my ol man and me @ 3510 rpm. Didn't know if it was the linkage adjustment or the boat ridin more level.
New update: went out today after setting the throttle linkage to engage immediately when you twist the throttle. Before it would engage after about 1/3 throttle. After I did that I checked to see when the carb plate fully opened. It was 100% open at half throttle. So I think should give me max rpm at half throttle. Start it up in the parking lot. Sure nough, 4250 at half throttle twist. So I take er out. I'm hitting 22 bumpin 23 at 3650. Now here's the really funny deal. That was at full twist. The carb fully opens at half twist. So I thought after a couple minutes let of to half throttle since it should run the same. Well immediately after lettin off it lost rpm. So between 100% down to 50% throttle I was loosing rpm. But the plate is fully open at 50% rpm. What gives y'all?
Mon May 28, 2012 8:12 pm
Post Re: Update- 1842 & 27 PD
A motor wraps up faster when there is no load on it.
Mon May 28, 2012 9:00 pm
Tue May 29, 2012 6:58 am
Looked closer tonight. Took a nut out blockin the throttle linkage plate from turnin. Got 3800 at 23 mph with me, my boy-75 lbs, my ill gal-55 lbs, and my dog-65 lbs. I'm good with that. Lookin forward ta runnin er myself.
Tue May 29, 2012 6:04 pm
def. should turn 25 with just you. Get those heads done and you are gonna have a really nice rig I do believe. BTW, what is a 120# control unit?
HOTSAUCE170 wrote:
Tue May 29, 2012 6:20 pm
Tue May 29, 2012 6:35 pm
Thanks Clay. Yup. You got er.
Heads will be done in a month er two. Lookin forward ta that!
Tue May 29, 2012 6:58 pm
I think you kinda misunderstood what Woodie was sayin. The motor aint gonna turn up the same rpm under a load that it will in neutral. Think about it like your truck. With just you & a 12 pk of beer, it'll peg out the speedo, but put a load back there like a big tractor or something heavy, & you can give it all the throttle you want. If the horsepower aint there, the rpm's won't be either.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue May 29, 2012 8:08 pm
Understood TC. Maybe I did a chit job a explainin it. Ta break er down simple, none a the linkage was adjusted right all between the throttle rod and the carb.
Wed May 30, 2012 6:03 am
Final update. Ran er tonight and bumped 25 and steady 24.
Gps said 29 at one point but darn sure that was a glitch.
Sat Jun 02, 2012 9:34 pm
dang right! Getting it where you wanna be.
Sun Jun 03, 2012 5:41 am
Users browsing this forum: No registered users and 36 guests
