It is currently Sat Dec 20, 2025 3:23 pm
Reply to topic  [ 26 posts ]
 18/48 35gtr speed?
Post 18/48 35gtr speed?
Picked up my motor tax free weekend. Runs good, Tim is noisy going down.
Was told this is normal? Have any of you guys experienced a high pitch squeal in your trim, while trim down.
Speed- 2 guys 145, 1 dog 28lb= 26.1 best
Mostly running 3500-4090 rpms at this speed
Any ideas, I pretty much expected this rig to run 28 consistently,
Boat is a 18/48 .125 sealed Double bottom, hunt deck, 6.5 ft rake, dry storage up front.
Idle is set pretty low i think ( 825) prop in the water. wants to die in deep water when going neutral to fwd, or n to rev.
IT IS WHAT IT IS!
YOU BRING YOUR HOUSE DOG HUNTING?.....
Thu Sep 13, 2012 7:57 am
Post Re: 18/48 35gtr speed?
Most people's speeds are inflated. Is it a gatortail boat?
Thu Sep 13, 2012 8:05 am
Thu Sep 13, 2012 8:08 am
Owen, it's not a gt boat, bt yea a couple of my buddies warned me of these inflated speeds. Just didn't know if my rpms to speed matched up. I'm trying to get te height correct on my transome, first run it sat real low so it was dragging the lower unit. I put a 1 in ss shim under the mount to raise it. Trimmed up in highest position, I can stick a 2x4 under the boat and the lower unit sits about 1inch from btm of boat. Abt rt?
IT IS WHAT IT IS!
Thu Sep 13, 2012 8:11 am
The Phillips screw?
IT IS WHAT IT IS!
Thu Sep 13, 2012 8:12 am
What hole where you running your pin in?
Thu Sep 13, 2012 8:13 am
Top pin
IT IS WHAT IT IS!
Thu Sep 13, 2012 8:14 am
Put it in the middle hole an run it that should help
Thu Sep 13, 2012 8:18 am
You will run 28 with nothing in the boat and one person. Trim up until you here the prop sort of WHINE then back it down a touch. RUN WFO that is usually your best setting for speed.
26 with 2 guys and a dog is about right.
bump your idle up to 1000-1200
The flatter your prop runs with the surface the more efficient the prop will push.
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Sep 13, 2012 8:19 am
Thanks maxxis, yea I kinda figured 27-28 alone good deal just wanted to pass my experience by you guys and get some good tips. This is my first surface drive, and just trying to figure this bad boy out.
IT IS WHAT IT IS!
Thu Sep 13, 2012 8:25 am
Basics for any briggs would be to have WOT neutral RPMS at 4250-4300, Idle about 1000-1200, and do NOT over fill the crankcase. 2 quarts only. Run 93 octane non ethanol fuel if possible.
The trim on the gtr is about as noisy as an oudboard. At least mine is. It is an electric motor.
Once you get some hours on it and the feel you will get better results.
Bayou Surface Drive
337-351-0362
Thu Sep 13, 2012 8:32 am
Good deal, I used
Mobil One 10w-30
Chevron 93
Stabil
As far as the trim, sounds normal like any gtr I have been in, bt goin down has an awful squeal. I called Hoyt and he told me it was normal w the new trim units, im having a hard time w it bc it sounds bad. I have a lil video w the noise if u could get me ur email I can email it. I cant figure out how to post video or picture
IT IS WHAT IT IS!
Thu Sep 13, 2012 8:39 am
The new hydraulic trim is similar to the Merc trim, it makes a high pitch squeal going down, just like a big outboard
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Sep 13, 2012 12:28 pm
This one squeals and grinds
IT IS WHAT IT IS!
Thu Sep 13, 2012 12:52 pm
Man that is a totall different trim unit than what I have on my 08 model. Yours is a heck of a lot faster than mine!!!! My only experience with hydraulics is on hydraulic steerin in a 4x4. Abnormal noise usually points to air in the fluid.
Bayou Surface Drive
337-351-0362
Thu Sep 13, 2012 1:09 pm
Thu Sep 13, 2012 1:11 pm
It seems it is VERY similar to the Merc Self contained unit.
Bayou Surface Drive
337-351-0362
Thu Sep 13, 2012 1:19 pm
Maxxis besides moving a little faster do you know what else is better about the new trim? More powerful?
Thu Sep 13, 2012 1:24 pm
Not sure. I have not had the chance to see one or personally use a newer motor yet.
Bayou Surface Drive
337-351-0362
Thu Sep 13, 2012 1:30 pm
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Thu Sep 13, 2012 1:33 pm
Faster, more powerful, longer lifespan
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu Sep 13, 2012 1:37 pm
Thu Sep 13, 2012 1:39 pm
I have a brand new 18 x 46 GatorTail hull that ran 28.5 mph with 2 adults and 12 gals fuel.
Thu Sep 13, 2012 2:44 pm
That sounds like a perfect size. I'd like to see a 1846 in person. I love the size of my 1644 but I will have an 18 next time.
1850 & 36pd
Thu Sep 13, 2012 3:21 pm
Bayou Surface Drive
337-351-0362
Thu Sep 13, 2012 3:41 pm
i run a 18x46, love the boat, been in places anything wider than that woudn't make it. I can do some scouting in this rig.
Thu Sep 13, 2012 6:55 pm
