It is currently Tue Apr 07, 2026 4:12 pm
[ 7 posts ] |
Joel907
 Pluming pipe ?
So I have my SS shaft 3/4 6 ft long #10 threads on One end and keyed on the other. But I can't find any 1in Id DOM If I go with black pluming pipe 1 1/4 will the seals still Work.
| Wed Oct 17, 2012 3:41 pm |
bigchevrolet
 Re: Pluming pipe ?
what seals? building your own i assume? 1 1/4 black pipe has a 1 1/4 id if your seals have a 1" od the 1 1/4 will not work. also most black pipe readily available at a hardware store is not seamless i would say dom is a must. contact a local fab shop or metal supply
| Wed Oct 17, 2012 6:17 pm |
Joel907
 Re: Pluming pipe ?
I have seen pic's on here of pluming pipe Being used 1 inch Inside diameter 1 1/4 od. Just wondering if the seals keep grease it.
| Wed Oct 17, 2012 8:45 pm |
Sandor27
Joined: Mon Sep 26, 2011 9:23 am Posts: 12 Location: Middletown, DE
 Re: Pluming pipe ?
| Thu Oct 18, 2012 6:41 am |
ironman_gq
 Re: Pluming pipe ?
www.discountsteel.com has everything you need too. I've ordered a lot from them, good to work with.
| Thu Oct 18, 2012 9:56 am |
Mag10
Joined: Wed Jan 14, 2009 12:31 pm Posts: 342 Location: Faribault, Mn
 Re: Pluming pipe ?
You could use standard black pipe but do not. There is no tolerance on straightness and it will also have an weld ridge on the ID that is a pain in ass to deal with. Spending the $ on DOM is worth it.
| Thu Oct 18, 2012 11:22 am |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
 Re: Pluming pipe ?
oh bull shit thats what they used to be them built with. its 1 inch shed 40 galvanized. use the couplers to make seal housings. you cut the threads in the coupler out to accept seals. if you want to use a bearing vs a bushing then use a bell reducer .
| Thu Oct 18, 2012 7:35 pm |
[ 7 posts ] |
