It is currently Fri Apr 03, 2026 5:52 pm
[ 7 posts ] |
DD
Joined: Thu Feb 14, 2013 7:28 am Posts: 179 Location: Central FL
 23 Vanguard GDLT
I have a 23hp gdlt on a 15/42 Grizzly Tracker, currently getting about 19mph solo. Running with full gear and extra man, around 15-16. What are the easiest ways to modify this motor and increase performance all around?
_________________ 16/42 crawfish skiff - 31GDLT
| Thu Feb 14, 2013 1:38 pm |
OlSchool
Joined: Sun Jan 06, 2013 4:24 pm Posts: 384 Location: Louisiana
 Re: 23 Vanguard GDLT
What was your max rpm solo. I can tell you a few simple things I did to my 23. I have a 16x42 weldbuilt 23gdlt. Running 21-22 solo light. 20+ two people. I'm turning 3850-3900 solo. Don't want to turn much more on bronze bushings. I have gained 3-4 mph with the following. Drop in K&N air filter, pulled head and cleans up exhaust and intake ports with dremel. Re-lapped valves and one of the more important steps...Adjust the govenor tab to 4000 out if water. I'm not interested in putting after market parts on it.
| Thu Feb 14, 2013 7:58 pm |
codyw
Joined: Tue Jan 29, 2013 7:05 pm Posts: 49 Location: Scottsboro Al.
I have a 23gdlt on 16/42 and it runs 23 with just me and gas. Only thing done to it is stock hutted muffler.
| Fri Feb 15, 2013 12:34 pm |
codyw
Gutted *
| Fri Feb 15, 2013 12:35 pm |
OlSchool
What Rpm you turning cody.? Do you have a floor in your boat?
| Fri Feb 15, 2013 5:28 pm |
139sst
DD, If that tracker boat is the older welded modified V than that speed is good. IF it is the new 1542 riveted flat 200# boat you should be running 23 empty. With the throttle lever in closed position, bend governor tab toward front of boat till you are turning 3950- 4000 out of water. Do not adust if you dont have a tach. Do not over adjust.
| Sat Feb 16, 2013 7:50 am |
codyw
I don't know I don't have a tach . And I have a half floor of marine plywood that's it.
| Sun Feb 17, 2013 8:00 pm |
[ 7 posts ] |
