It is currently Mon Apr 06, 2026 12:43 pm
Reply to topic  [ 7 posts ]
 23 Vanguard GDLT
Post 23 Vanguard GDLT
I have a 23hp gdlt on a 15/42 Grizzly Tracker, currently getting about 19mph solo. Running with full gear and extra man, around 15-16. What are the easiest ways to modify this motor and increase performance all around?
16/42 crawfish skiff - 31GDLT
Thu Feb 14, 2013 1:38 pm
Post Re: 23 Vanguard GDLT
What was your max rpm solo.
I can tell you a few simple things I did to my 23.
I have a 16x42 weldbuilt 23gdlt. Running 21-22 solo light.
20+ two people. I'm turning 3850-3900 solo. Don't want to turn much more on bronze bushings.
I have gained 3-4 mph with the following.
Drop in K&N air filter, pulled head and cleans up exhaust and intake ports with dremel.
Re-lapped valves and one of the more important steps...Adjust the govenor tab to 4000 out if water.
I'm not interested in putting after market parts on it.
Thu Feb 14, 2013 7:58 pm
I have a 23gdlt on 16/42 and it runs 23 with just me and gas. Only thing done to it is stock hutted muffler.
Fri Feb 15, 2013 12:34 pm
Gutted *
Fri Feb 15, 2013 12:35 pm
What Rpm you turning cody.?
Do you have a floor in your boat?
Fri Feb 15, 2013 5:28 pm
DD, If that tracker boat is the older welded modified V than that speed is good. IF it is the new 1542 riveted flat 200# boat you should be running 23 empty. With the throttle lever in closed position, bend governor tab toward front of boat till you are turning 3950- 4000 out of water.
Do not adust if you dont have a tach. Do not over adjust.
Sat Feb 16, 2013 7:50 am
I don't know I don't have a tach . And I have a half floor of marine plywood that's it.
Sun Feb 17, 2013 8:00 pm
