It is currently Thu Apr 09, 2026 12:01 am
Reply to topic  [ 8 posts ]
 RPM in water
Post RPM in water
Hello guys. Newby here I just finished a 212 predator longtail like the stump jumpers. It is running around 37-3800 rpm out of water . What should the rpm be in the water? I am putting it on a layout boat that I built. It is basically 36"x11'. I put a hill 7x4 prop on it... Any input would be greatly appreciated Thank you
Sun Jan 19, 2014 12:22 pm
Post Re: RPM in water
Should be anywhere from 3200-3800
1436 Lowe
Wed Jan 22, 2014 1:37 pm
Thank you for the reply... I finally took it out and it ran about 28-2900 rpm in the water ... It pushed the boat about 11-12 mph. So my guess is that it is over propped ? I will prob end up ordering a 6.5x4
Wed Jan 22, 2014 4:31 pm
Pm duckystyle or ghetto. They have the same motor. Ask what prop they got
23 swomp/ 1542 tracker
Wed Jan 22, 2014 4:37 pm
Thanks. I did pm duckystyle before I started the build but never got a reply. Ghetto has a hopped up engine and mine is still stock (for now)
Wed Jan 22, 2014 4:41 pm
Duckystyle had a great idea with the aluminum prop adapter... I should of did that to find the correct prop, then ordered the SS one
Wed Jan 22, 2014 4:44 pm
Just hop up that engine and get it to that rpm range, it can be done relatively cheap from some go cart sites, for just about the same as buying a new prop you could just get a kit and hop up your engine... hell if it blows up you can get another at harbor freight for $99 (with coupon)...
1436 Lowe
Wed Jan 22, 2014 10:05 pm
Thu Jan 23, 2014 12:05 pm
