It is currently Thu Apr 09, 2026 12:47 pm
[ 8 posts ] |
Quacksmackerdb007
 RPM in water
Hello guys. Newby here I just finished a 212 predator longtail like the stump jumpers. It is running around 37-3800 rpm out of water . What should the rpm be in the water? I am putting it on a layout boat that I built. It is basically 36"x11'. I put a hill 7x4 prop on it... Any input would be greatly appreciated Thank you
| Sun Jan 19, 2014 12:22 pm |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: RPM in water
Should be anywhere from 3200-3800
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Wed Jan 22, 2014 1:37 pm |
Quacksmackerdb007
 Re: RPM in water
Thank you for the reply... I finally took it out and it ran about 28-2900 rpm in the water ... It pushed the boat about 11-12 mph. So my guess is that it is over propped ? I will prob end up ordering a 6.5x4
| Wed Jan 22, 2014 4:31 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 Re: RPM in water
Pm duckystyle or ghetto. They have the same motor. Ask what prop they got
_________________ 23 swomp/ 1542 tracker
| Wed Jan 22, 2014 4:37 pm |
Quacksmackerdb007
 Re: RPM in water
Thanks. I did pm duckystyle before I started the build but never got a reply. Ghetto has a hopped up engine and mine is still stock (for now)
| Wed Jan 22, 2014 4:41 pm |
Quacksmackerdb007
 Re: RPM in water
Duckystyle had a great idea with the aluminum prop adapter... I should of did that to find the correct prop, then ordered the SS one
| Wed Jan 22, 2014 4:44 pm |
SwampDonkey1
 Re: RPM in water
Just hop up that engine and get it to that rpm range, it can be done relatively cheap from some go cart sites, for just about the same as buying a new prop you could just get a kit and hop up your engine... hell if it blows up you can get another at harbor freight for $99 (with coupon)...
| Wed Jan 22, 2014 10:05 pm |
DrahthaaRunner
 Re: RPM in water
| Thu Jan 23, 2014 12:05 pm |
[ 8 posts ] |
