It is currently Fri Mar 27, 2026 1:09 pm
Reply to topic  [ 4 posts ]
 removing ujoint from 23 GD longtail
Post removing ujoint from 23 GD longtail
I took the motor off of the frame, and I'm trying to get the joint off of the crankshaft. I tried to knock the key out like i did for the driveshaft side but it ain't going, I want the joint completely off of the motor/crankshaft not just the u joint out of the yokes. I searched for this and couldnt find any answers
Wed Jul 28, 2010 3:33 pm
Post Re: removing ujoint from 23 GD longtail
I put a 3 jaw pulley puller and heated the yoke till it was red, and that did not work. The last time I removed the yoke on the motor side I carefully cutting it off. It was a B#@*^. Good luck
We all suffer 1 of 2 things; The pain of Discipline or the pain of Regret. Don't Regret
Fri Jul 30, 2010 3:19 pm
Both the UJ yoke and the crankshaft are both carbon steel and liable to rust together because of the wet environment. So soak the thing in some kind of rust loosen all from the auto parts people for a while. It will make a difference.
Mark F. Cheney
on the Great Salt Lake marsh
Sat Aug 07, 2010 8:36 pm
if and when you get it off put on some anti seize to keep it from rusting together again
15 Ft. War Eagle with a 23 HP GD LT
Sun Aug 08, 2010 6:16 am
